Spec me an ITX build
15 Jul 2010
Can someone spec me an ITX build?
The GPU doesn't have to be powerful, only able to run games like WoW, STWOR,GW on low-medium settings.
Don't need the operating system or a monitor.
Hopefully as cheap as possible :D
I was looking for something more around £300 or less if possible.
I have a main gaming pc, this is just for multi media setup
crossfire 6770's? a £130 H67 motherboard? really?
*edit*
i was so shocked at the crossfire 6770 recommendation that i forgot that mini itx only has 1 PCIe x16 slot, so thats impossible to run with
*/edit*
heres my recommendation.
YOUR BASKET
1 x OcUK GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card £95.99
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £88.79
1 x Asus P8H61-I Intel H61 (Socket 1155) DDR3 Motherboard £64.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £62.99
1 x Samsung SN-208BB/BEBE Slimline 8x DVD±RW SATA Drive - OEM £18.98
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £17.99
Total : £361.13 (includes shipping : £9.50).
i havent included a case or PSU because i would really recommend going elsewhere for the case since OcUK has the choice of 1 mini itx case that can take a graphics card as well. unfortunatly it has a low power PSU that is a funny size so cant be replaced easily
i would have a loog for the silverstone SUGO SG-08 because that can take any length graphics card and a standard size PSU.
before buying anything i would head over to the small form factor section for a recommendation
