- 3 Jan 2010
Ah, well I am a noobGet a HDMI to DVI cable![]()
Ah, well I am a noobThanks for the help. I will get a HDMI to DVI cable to go with the monitor then as that is the ideal monitor with that solution. Thanks.
Okay dual link it is, thanksGood stuff, make sure you get a dual link hdmi-dvi cable.
Let us know how you get on with the screen![]()
Hi guys, I'm looking at getting the U2412M because I'm wanting the following
-1920 x 1200p res
- IPS
- LED
- HDMI
But I'm noticing it doesn't have a HDMI. Would that matter? I have blu-ray drives so when it comes to a monitor I want one good for gaming and good for blu-ray movie playback but it's hard to decide which monitor when none seem to have all the above. Do you think I should get the U2412M anyway and it'll be fine for blu-ray playback or is really better with HDMI cables and I should be looking elsewhere?
Okay dual link it is, thanks![]()
Hi there,
You mention blu-ray playback. Would this be via a PC or a stand-alone blu ray player?
If you plan to use it with a PC then I wouldn't bother getting a HDMI to DVI cable - as you can happily use the DVI-DVI cable that comes with the monitor to hook it up to your graphics card.
If you plan to hook it up to a stand-alone blu-ray player (or PS3/Xbox 360) then I wouldn't suggest going for the U2412M - since not only does it lack a native HDMI port but it also lacks 1:1 pixel scaling - so the 1080p (1920x1080) image produced by the player/console will be stretched vertically on the 1200p (1920x1200) monitor. Instead a 16:9 monitor like the Dell U2312HM would be a better choice or a 24in 1200p monitor that does 1:1 pixel mapping like the Dell U2410.
It would be via the PC, I have 2 blu-ray drives installed into the tower and the cyber power software to run it so it comes straight from the PC. Seems like I can stick with the monitor and not bother with the cable then which is easier then overall. I guess the DVI - DVI cable should do the trick then.Hi there,
Well that's what I was told1920x1200 doesn't require dual link![]()
But if he's buying a new cable, he might as well get a dual link one for the same kind of cost, who knows what he'll use it for in the future?![]()
Use the onscreen menu to select the relevant connected port, mine was the same, took me a minute to work out it doesn't auto switch, but once saved it'll remember![]()
Just letting everyone know I've got it all set up now, the DVI cable is working, no more black outs / weird desktop but no files thing. Everything is working and looks fine so thanks to everyone who helped with comments.
