Remote reboot (Server 2008 R2) over internet
1 Dec 2004
S.Wales
Hi all,
I use a small batchfile utilising the shutdown.exe feature for restarting/shutting down my Server 2008 R2 box from another machine on the LAN, however want a similar script to work if I am not on the same network.
I have some options which I am looking at
1) Similar batch file to restart over the WAN (then if needed set-up some port forwarding on my router (or is this not reccomended)
2) Test out tweetmypc, little app which runs on the server, then create a new twitter account, and you can log in to this twitter account and "tweet" certain commands to shutdown/restart), seems ok but not 100% until fully tested
3) Just set-up a VPN server on the Server 2008 box so I can VPN in, once on my network at home I can then use the batch file I normally do as I would essentially be on the same network.
What you think?
What email gateway do you use?
MailMarshal allows script triggering.
IE you send the command via email to a certain address with a keyword (password) in the subject followed by the script command.
RDP is a no no, partly the reason I am doing this is because when connecting to my server remotely over RDP, the session will just disconnect the session if I leave it connected for a bit (10-15 minutes), then everytime I try to reconnect over RDP, I will authenticate via RDP fine, and will go straight to a black screen each time.
I can only RDP properly back to the main desktop after a server reboot, I have been trying to find out if this is a known issue with RDP on Server 2008 R2, however for now I will just use team viewer to reboot until I find a permanent solution for this RDP issue.
It only happens if I log in and leave a session open for a long period of time. If I log on, do what I need to do, then log off it won't happen.
When you connect, are you specifying session 0 to connect to using /admin in the command line?? I get the same issue in that I get a new session each time that is blank but session 0 is fine.
