What exactly is the advantage to using that little remote controlled drone the recon class gets? Does it just tag enemy troops on your team's map? You dont seem to get any points for doing it.
Spots enemies, can be used to destroy enemy equipment like spawn beacons and soflams and of course as mentioned it can be used to kill the enemy, hopefully that exploit will be patched soon.
