The is still plenty of space about and from what Sylvet/ToString said before 1.2 is bring new biomes but chunks won't be able to load in the current map? With that maybe the admins can claim a big chunk of this new expansion for copying jungle biomes etc, it could become the new unstable land etc
There seems to be some confusion, my explanation here: http://forums.overclockers.co.uk/showpost.php?p=21131278&postcount=7175
1. There is plenty of space on the current map.
2. When 1.2 arrives, extending the borders will not give 1.2 biomes/terrain.
3. Transplanting 1.2 will most likely result in mismatched biome/terrain and no ocelots.
If I get time later I'll generate some renders that show what would happen.
I'm sure you mentioned about the new biomes not being generated with out current map so the only way to get them would be to copy them via world edit or create artificial ones. Both with Pros/Cons.Is it possible I can have all my chests from 1.7 world? Not bothered about buildings was too hard to sort coords.
Ah that is what I was trying to sayI'm sure you mentioned about the new biomes not being generated with out current map so the only way to get them would be to copy them via world edit or create artificial ones. Both with Pros/Cons.
Is there a patcher/mod we can implement to add the 1.2 biomes into the current map?
i know it's most probably a long shot, but im sure that most people on here would love to see jungle biomes in the 1.1 map, without having to move maps on every upgrade.
Hindrance : are you going to building outside your castle, I have some ideas by my green house, it will include a route to your build.
this will include.
a water fountain.
paths
meditterian walls
flowers and trees.
Cartos!
http://linktart.co.uk/2012/01/cartography-30012012/
Cave, Nether and The End are all last weeks as I don't think there are enough changes to justify new ones and I'm short of time today
1.7 is being carto'd as I type this so it should be added in the next 30mins or so.
Very happy with the way my house looking on the cart just a shame about the grass colour change.
Cartos!
wheres is yours?
Yeah I noticed dan/mrbios have multicoloured lawns too![]()
lolbiomes
