Hi,
For some reason, I'm having problems acheiving this.
I want to run two separate versions of Windows 7 (32bit & 64-bit) on one machine, however I've been able to install on this Dell laptop.
Two separate partitions on the one HD. 1st partition everything installed fine, and I used the typical dual boot setup procedure for the 2nd. ie, leaving the 2nd partition free, and done everything at the time of setup (partition creation and format) Everything went through as it should do, ie copying windows files, expanding, installing feature and updates, then right until the end where it says Completing installation ! the error I'm getting is Windows is unable to start on this hardware. Same deal, if I reboot and just go to boot off the 2nd install / partition.
I'm thinking this is perhaps a licensing or purposely blocked issue, since this is a Dell machine and i'm using two separate Dell OEM Win7 discs to do the installs.
Anyone else encountered the same before?
