I got a cycling coach who I've seen once a week since Christmas.
Really?! I'm actually amazed that someone an amateur would pay a coach to give them cycling routines. Can you not figure it out a routine yourself?
An awful lot more than that!What value does it provide...mainly motivational?
Really?! I'm actually amazed that an amateur would pay a coach to give them cycling routines. Can you not figure it out a routine yourself? What value does it provide...mainly motivational?
But you do realise with events like the KK it's not about the time you put in or the fact that you 'beat' other people, it's about the fact that you did it and completed it that makes it fun. It's the fact that you can actually physically do itHe doesn't motivate me, I motivate myself. I'm scared of the KK parcours, and want to complete it in a decent time. Fear is the motivation in this case.
For some people, it's all about beating other people. That's what makes people go pro, after allBut you do realise with events like the KK it's not about the time you put in or the fact that you 'beat' other people, it's about the fact that you did it and completed it that makes it fun. It's the fact that you can actually physically do it![]()
I think something seriously wrong could be potentially emerging.
I'm not an expert by any stretch, but i think the headset is the core of the issue. Basically when i go for a ride now, i'll come back (even after my 4 mile commute to work) to find the fork and handlebars have come slightly loose and now are able to tilt independently of the frame if you see what i mean.
As a solution i loosened the stem bolts and tightened the bolt on top of the headset, this stops the movement. I then tighten down the stem.
Unfortunately after i go out riding again it works itself loose. It's not a huge amount of play, but its enough to make me worry.
Any suggestions what the cause/solution could be?
[EDIT] Loosened the stem bolts all of the way, tightened down the top bolt and tightened the stem screws down again. Haven't got a torque wrench so kinda winged it, hopefully i haven't done any damage. Seems to be nice and snug now, i guess we'll see what happens on my commute tomorrow. Getting the front wheel straight was a pain!
That is how you nip up a headset but if the bearings are worn it will just become notchy and/or work loose again.
I don't know what bike you have but bikes with carbon steerers have an expanding bung inside that grips on the inside. These usually need tightened every so often before you tighten the top cap.
Just signed up for the two Shakespeare rides this year. April 1st is a 60 mile event & September 9th is the 100 mile event.
Also got the 75 mile Sunrise Express ride on February 18th. Gearing up to be a good year.![]()
Any suggestions or am i doomed to taking it to the LBS and getting them to have a look?
Damn headset has come loose again. It's only 1/2mm of play and doesn't really affect my riding, but it is a visible amount of play. I've nipped it all up twice in two days but it still works itself loose after just 4 miles of cycling. It's still effectively a brand new bike, so i don't see how it can be wear. I've got a torque wrench in the post so should be able to make sure it's all torqued up perfectly when that arrives, but i'm not holding out much hope.
