Upgrade Help or new system build
17 Aug 2010
Birmingham
Hi guys im in need of help. I would like to know if i should upgrade certain.parts or upgrade everything.
My specs
Nforce 790i ultra sli
asus hd6870
4gb ddr3 1600mhz intel low.voltage
1tb samsung f2
Intel q9450 overclockd at 3.5ghz
Dont knw what psu it is
Its an alienware area 51
i was thinking of changing the mobo and cpu but dont knw to which once.
I would really appreciatw the help.
Well it will acctually depend on what I should do. If i should just change mobo and cpu or the full system. Budget is £500 as I also want to change to a water cooler.
Whats this PC to be used for?
First glance tells me theres nothing wrong with your current CPU/board/RAM
Definitely need to find this out, any upgrades depends on the quality of the PSU, never skimp on this as low budget/low power PSU's cant deliver the wattage they say they can .
Its used for gaming. The reason why i want to change is that the mobo as I was told is messd up. As whilst playing games it freezes the system and had it send down to repairs twice. Also i wanted to change the case and fans.
Had a look around,
Your basketProduct Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £161.99
(£134.99) £161.99
(£134.99)
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard £99.98
(£83.32) £99.98
(£83.32)
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £62.99
(£52.49) £62.99
(£52.49)
Cooler Master Elite 430 Windowed Case - Black £39.98
(£33.32) £39.98
(£33.32)
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £24.98
(£20.82) £24.98
(£20.82)
Sub Total : £324.94
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £67.34
Total : £404.03
• There is £20 off the Case+PSU - http://forums.overclockers.co.uk/showthread.php?t=18347004
• Motherboard does SLI/Crossfire at 8X/8X
Plus £20 off makes it £530
