Ok so for the past week and half now I've been back n forth over ideas of a cpu cooler but I just can't seem to find one that Will fit.. or if it will, I just dont Like it..!
I know this sounds probably a little fussy, but I just don't want to settle for something I'm not happy with..
So.. I have a MSI Z68S-G43 (Gen3) 1155 Board..
This image isn't my board but... its pretty much bang on to how much room I have to my ram modules.. My Board may have a couple of mm extra in the space between fan mounts and ram slots but.. its very minimal to what you see in that pic.. its around 5-7mm at an approximate.!!!
I also Have Corsair Vengeance Memory so those with experience will know
these sit pretty high off the board..!!
Height of modules is;
-- I Really would like to avoid one of the AIO H20 Coolers (ie; antec kuhler 620) purely becasue I don't like the look of the tubing and I really don't fancy havin' it sprawling its way across my system..
Kinda need a cooler where the face of the fan sits with a maximum overhang of 5mm from the mounting holes on the plate / board .. orr if mounted with fan pointing downwards (i have 2 x 140mm top exhausts on case) then i need the side of the cooler to have either enough height clearance for the ram or also to sit with at most a 5mm overhang from the mounting points..
It's a Painstaking task looking at coolers, reading the reviews to cooling performance, then if its worthy having to find out its exact fitting dimensions..
(some are easy to find.. others not so..)
So.. Calling on the Experience of OCUK members and customers.! Surely someone out there has the answer.!!
