Ohayo!
In few upcoming days I'll be ordering all the remaining parts for my new system, and I rather double check that I am making the right choices.
First of all I'm listing few things I already own:
And this is what I will be probably getting:
Total for everything is about £2600. Now, my concern is if I should take i5 2500k instead of 3930k and get another HD7970 for EF gaming, or just leave it as it is(2xHD7970 + 3930K) and wait for HD7990.
The bad thing about Z68 setup is that I can fit only 2 GPU and the soundcard on the mobo. Which means if I would like to add another GPU in the future I won't be able to do that because of it, so I will have to either remove the soundcard or just stick with 2 GPU.
Any advices?
- 3 x Dell U2312HM
- Creative Titanium HD
- AKG K242HD
- Razer Mamba
- Razer Vespula
- Logitech X-540
- Samsung F3 1TB
- +Other crap...
- Intel i7 3930K - Now you might ask if I do any heavy stuff, the answer is no. I do have dSLR camera, and I will play with Photoshop or some video editing, but for that 2600K would be way enough. So the reason I'm looking at 3930K is 6-cores, more futureproof, and I will run heavy GPU on it.
- Asus Rampage IV Extreme - Design, and PCI spacing. I will be able to fit in 3 GPU with my soundcard. So when HD7990 comes out, it will be QuadCF.
- Corsair Dominator 1866Mhz 16GB - Yeah, overkill, but it's X79!
- Corsair H100
- Corsair 800D - So many people have it... I want to be unique... good case tho.
- Corsair 1200AX - Well, X79; 2 GPU. In future QuadCF, Water Coolig.
- Crucial M4 128GB
- Sapphire HD7970 x2 - Good for eyefinity, from what I've seen and heard.
- Logitech G510 - Can you access BIOS with this keyboard? I've seen people having problems with it.
- Samsung DVD Blu-Ray
Any advices?
7990 quadfire will probably cost as much as you're currently willing to spend (well maybe half as much) and is totally pointless, though your e-peen would be huge
. One final thought, 2011 gets hot, if you're gonna push a decent overclock on that processor, the H100 will just about do the job, but you should really be going down the custom loop route (just get one 7970 for now and spend the saved £500 on custom water).
