PC Won't start = PSU?
21 Oct 2011
Hi
I was wondering if you could help me please, I built a PC at the beginning of Dec, it's been working perfectly until today, just browsing the internet... PC shuts off. Went to turn on, nothing, well the fan on the PSU came on for a millisecond and then dead, I unplugged the mains and left for a while, same thing happened, just a millisecond of life, then nada.
The PSU concerned is one which was recommended here "BeQuiet Efficient Power 600W '80 Plus Gold' Power Supply", its running a i5 2500K, Gigabyte Z68AP-D3 and a single ATI Radeon HD 6850 card.
Any advise would be gratefully received. :)
Pull the Bios battery out wait 31 seconds then put it back & try again.
Any life from the motherboard (lights?) any CPU fan movement?
Try the "paper clip" trick on the PSU.
Use the bare minimum need to start up (one stick of RAM/GFX etc)
you can tell if its the PSU by unplugging it from the motherboard and then bridging the power pins with a bit of wire (while turned off) and then turning it on.. see if fan spins etc. Then you can connect fans and stuff to it to see if they start if so then the PSU is working
hot google for "switch PSU on without motherboard"
Thanks guys, I've just tried the PSU wire trick and it's the same, fans spin for a millisecond then nothing, so a dead PSU I presume? better RMA it, it's only 57 days old!
you had the PSU plugged into NOTHING else? then yeah sound like its borked
Hi
I had a similar situation with my old skt 775 system.
Fans would spin up for a short time but no boot etc.
I bought an Antec PSU tester and the PSU tested fine and is currently powering my Sandybridge system.
So in my case, it was either the CPU (Q6600) or more likely the Mobo that failed.
Also, remove mobo from case and re-test to rule out shorting
Sounds like it's the PSU. Does it have a warranty?
Yes it's only 50 odd days old.
Luckily I had the "old" PSU which it replaced, put this one in, bingo system alive and well now.
I'm not going for a exchange, I would prefer another make, once bitten , twice shy sort of thing, it was recommend that I brought a Corsair, anyone else have a recommendations? I would really like to spend about £70-80ish if possible.
