SATA2 Vs SATA3??
25 Nov 2011
The KOP
Hello the motherboard i'll be using is Asus p8z68-v pro Gen3 Should I go with SATA2 or SATA3?
Am looking at getting Western Digital Caviar Black 1TB Hard Drive witch is SATA 3
Thanks guys, talk later.
With mechanical HDD's like the WD Caviar Black it makes no difference whether you get SATA II or SATA III. It's a marketing ploy as mechanical drives can't even fully utilise the bandwidth of SATA 3Gb/s nevermind 6Gb/s. Get the SATA II one if its cheaper.
Thanks guys the sata 3 one is cheaper then the sata 2 one I was going to get. Only by 2 pounds like. Watching some YouTube benchmark of the drive early on and it was doing much faster than the same sata 2 drive.
I understand what you saying but check this out
does seem to give a big boost.
I might has well just go with sata3 seeing as its a new build.
That video is rubbish.
If it compared two otherwise identical drives with SATA 2 and SATA 3 then you'd be able to see if there's a difference (FYI there isn't).
But it doesn't
It compares two completely different drives one of which happens to be SATA 2 and one SATA 3.
I've got SATA 2 drives here which benchmark at least as well as the SATA 3 drive in that video.
But it doesn't
So i just get sata 3 because its cheaper than the sata 2 drive I was looking at anyway.
