Pentax enters the fray with a K-mount, APS-C mirrorless camera:
Features:
Hands-on Preview:
Design:
Pricing:
Expected at the end of March.
I'm not too sure about the design, the image quality promises to be better than that of the K-5. Big lenses will look strange hanging off it. It's not making me excited.
Features:
Durable machined aluminum frame under a stylish black, white, or yellow exterior.
PENTAX mirrorless body design is compatible with 25+ million PENTAX K-mount lenses spanning decades.
Large 16 megapixel APS-C sized CMOS image sensor with low noise image capture and multiple aspect ratios.
Bright, high-resolution 3-inch LCD with 920,000 dots.
Full HD 1080p video capture at 30 FPS with h.264 compression (60 FPS at 720p) features outstanding video capture flexibility.
Sensor-shift PENTAX Shake and Dust Reduction system is compatible with every mounted PENTAX lens.
Fast 6 FPS burst mode is ideal for fast-action photography.
Flexible ISO range of 100-25600 ensures gorgeous noise-free imaging in any lighting condition.
Focus peaking mode provides fast and accurate manual focusing for critical focus applications.
Battery: Rechargeable Lithium-ion Battery D-LI90
Dimensions: 121(W) × 79(H) × 59mm(D) (excl. operation parts and protrusion)
Weight:560g (loaded with batt. and SD card), 480 g (body only)
Hands-on Preview:
Design:
Pricing:
The SRP of the body is £629. With the new 40mm or the 18-55mm - £679, or the twin kit is £799.
