Simon, what remap have you got? Is it worth getting one done? I have got the urge to put a loud exhaust on and remap mine. I'm a bit sad that the fly by wire cars can't be supercharged.
I much prefer the look of the later models. I looked at a few early and late models side by side and the updated headlights, led tail lights etc just seem to lift the car if you know what I mean.
Like you say, it's only 3k ish more than a tidy rev2 that's been looked after and, as Sin says, I can get the geo done soon and if it's seized I can just go straight to Honda and demand it be fixed under warranty. That's 1k saving right there.
At the end of the day, it's a toy for me. It was the right model, in the right colour at the right price. Can't say fairer than that.
I wasn't planning on buying just yet but the deal offered ticked the right boxes in my mind so I figured; what the heck.
Looks good Rilot.
Read your thread in GD, hope things get sorted out mate.
9200 rpm and 260 horses sounds more than standard...?
It was modified with exhaust system and decat and some thin oil
9200rpm is the rev limit on mine as it's an early one, although a lot of informations does suggest a 9000rpm limit
Well that solves one of life's little mysteries! I had been wondering about that.
Stories of insane reliability make me love these more and more!
Engine reliability sure, but suspension wise not so much. I am under the impression they are just over £1k to put back to standard once they seize.
What are these like on the motorway? Is it something you could live with for 25k miles a year?
What sort of mpg?
The only need unseizing if they need adjusting. If they are stuck in standard positions then you don't need to fix it.
