Watercooling spec
Temps wont be hugely different to the phantek, it's mainly the expandability that will be affected as you can probably get away with adding a GPU to the loop :)
The OcUK V8 kit will be perfect :D
Custom water will (nearly) always be better than air cooling. You say he can only fit a 240 rad in his case, what case does he have? It may be possible to fit a 120 on the back as well?
Corsair 600t
http://www.overclockers.co.uk/showproduct.php?prodid=CA-043-CS
how would say this spec (did myself looking at a few others compared to the £200 V8 kit)
YOUR BASKET
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
1 x XSPC EX240 120mm Radiator - Black £39.98
1 x EK Single Bay Reservoir - Acetal £35.98
1 x Mayhems Pastel - Gigabyte Orange Coolant 1L £14.99
2 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £14.99 (£29.98)
3 x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear £2.99 (£8.97)
8 x OcUK 1/2" G1/4 - FatBoy Style - Black Nickel - Barb Fitting £1.68 (£13.44)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
Total : £298.60 (includes shipping : £10.00).
only 2 fittings and a fan are needed for another rad.
I would personally go for the EX rad as it is thin and maybe go for a thicker top rad such as an RX/phobya g changer/SR1 or EK XTX
