i have bought dt770 pro 250ohms cans and there running off my asus xonar dg 5.1 card and they sound good. but would i get even better sound using a seperate headphone amp or asus xonar essence stx card
Some people might argue that an amp can improve sound if your existing card is incapable of powering your headphones sufficiently.
Yup - in fact I did exactly that three posts ago!
them the amp isnt improving sound its simply giving enough power to the speakers to produce the sound as intended
my point is your buying an amp to fix the card's low quality............................just buy a better card
It's true an amp can't improve the output of the source, but adding an amp to a system can certainly improve the overall sound you hear through the headphones. It isn't always a question of power either, and all I was suggesting is that adding an amp can provide a major sound quality upgrade by controlling headphones better than a high output impedance card. Of course you're right that buying a better card can also improve the sound, but with the OP's headphones I'd say an amp will ultimately be needed to get the best out of them.
But since both the Xonar DG and the Xonar Essence STX already have a built-in headphone amplifier, it doesn't seem obvious to me that a separate headphone amplifier would necessarily improve the sound unless the built-in amplifiers were incapable of driving the DT770 headphones properly. Asus claim that the Xonar Essence STX is capable of driving headphones up to 300 ohms.
You're right, it's not obvious and there's no reason why a card with a dedicated amp shouldn't do as good a job as a separate amp.
I'm just stressing that driving headphones well is more than just driving them loud.
I think the Essence STX headphone out is about 10 ohms, so you won't get the voltage divider effect I described with high impedance headphones.
hehe
