Who do you think I am, kwik fit? eventually would get caught out by one that knows his/her ****It's probably easier to tell customers a lot of wrong things though, what difference does that make?![]()
are you implying I lie to my customers now?Glad I'm not your customer![]()
are you implying I lie to my customers now?![]()
[TW]Fox;21199647 said:It would be even easier to say 'Dave' whilst being just as wrong.
To be honest, from reading your posts, my initial assumption wasn't 'he must work in the motor trade'
poor maintenance is the blame not the car. always look for evidence of work done, service book or recites with reg
I'd buy it after having a look at in person and see what work needs doing. it might need ony a shock,starter and some bodywork but on the other hand it might need a lot more
...the PD engine in 110/115/130 form is still a very decent performer, economical and as reliable if not more reliable than the competition.
I would personally buy a passat, consider the Octavia (based on the golf but it's plenty big) and ignore the A4. Look for something that's had a cambelt & waterpump recently, be prepared to refresh some of the suspension and you're good to go...
That can mean anything though, I travel for work yet only do 12k a year. Some people think that's a lot of miles when it's far from it.
the audi, vw, seat and skoda are owned by V.A.G vw audi group so they all have the same pros and cons as they as they are the same car underneath. although the labour is different for each marque but you can maintain your car at skoda labour. but an independent using ome* parts will be cheaper then dealer using genuine parts
* ome is exactly the same spec and from the same manufacture as genuine but with out the designer box and much cheaper![]()
Around three times that I guess.
[TW]Fox;21202518 said:36k a year dog work on your personal car!?
naa easer to say vw audi group when dealing with customers, else it would be vag and aag and that would confuse customers, although now its more like vw, audi, seat, skoda lambo bently bugatti group
[TW]Fox;21198593 said:No they won't - VAG only recently moved to CommonRail (Well, in the last few years).
Fox, what is wrong with common rail diesels?
I take it my mothers 57 A4 2.0 diesel is common rail? I've been thinking about getting one myself (although hers is the 140 auto)
