HD6870 Bottom DVI port dead.
12 Dec 2005
I purchased a gfx card from the MM and it arrived today. I installed it with the latest drivers.
I have 2 monitors which both are VGA so I use VGA to DVI connectors on both of them.
The top DVI port on the card works fine but when I connect another monitor to the port underneathe it I get no signal at all. I've swapped them around and they both work so I know it's not a monitor issue. As said the bottom port just seems totally dead.
Is this a faulty card or something else?
Cheers
Try Windows button and P. I think that's what it is.
Nothing will happen until you tell the card what to do if memory serves.
IE ; when I connected my TV to the HDMI port on my 7970 nothing happened.
The bottom DVI port is DVI-D only, it can't send VGA signals.Try a DisplayPort to VGA adapter instead?
