- 18 Mar 2011
- East London.
I plan to water cool the following:
What i want to know is what kind of minimum requirements i need for this lot in terms of number of rads and size of rads. Also what would be optimum for these and what would be 'just right' ?
Cases: im having trouble deciding on a case for my build. I had originally decided on the Fractal Design Arc MIDI - however build quality issues are disheartening me from that one.
Corsairs 600T, and the other Corsair alternatives, although nice as they are, way too big for my liking.
So regardless of case size can you recommend the Rad solution?
Thanks.
- i5 2500k CPU - overclocked.
- Either, 460GTX SLI or 560TI SLI, overclocked
- Mobo/chipset for the Z68-UD7-B3, (not sure if available yet)
Thanks.
