I enjoy it all if I'm honest, I'm not going to lie though... The feeling of carrying your team is nice. I know as a jungler I make a big difference but feel as a carry I make a huge difference. You are right though other can and do fail but if another lane gets fed at least I can do some damage to them as a carryYou do that and top/middle or jungle won't do so well. Unfortunately it's just how the game can goPlay what you enjoy....
Talon is amazing mate, he can carry hard and counters most AP, once you're 6 your harass is godlike.Can hopefully afford Talon in a bit![]()
Soraka is mean in mid, people really do underestimate her. She is one of the toughest champs I've ever had to play against in mid... However she does generally generate a lot of flames from the team which in term can make people feed etc... My brother used to play her in ranked as AP mid, while I'm not saying I agree or disagree with this... People would AFK etc because of it. I mean it's great early game don't get me wrong but imo as an AP carry falls off late game.snip
Yea that is my fav Brand skin to be honest. Out of interest do you smart cast? Since I started smart casting I've found Brand to be so much easier to melt face.snip
Haha, it's why I buy a skin before I play the champsnip
Yeah ive got a skin for all my main characters, got super teemo, arctic kennen shaco that looks like joker, golden alistair although i don't use him and another one i think ^^ btw whats smartcasting? Still kinda new to LoL![]()
Yea, it's all about the skins! Although don't get me started on that -.-
Ok you know when you press a spell you then have to click again to cast it? You remove that so it just casts. So something like Kennen's throw shruken thing ( thing it's Q ) would mean wherever your mouse was when you pressed Q it would throw in that direction, very very handy for skill shot champs. Took a little bit of getting used to it but I've noticed a huge gain in my abilities, especially with champs like Ryze, Ezreal, Brand, Lee Sin, Caitlyn etc.
You can do it if you hold down shift + q/w/e/r or you can change it in the options and set just qwer for smart cast.
I was trying it when I ended up playing a game as Ashe which probably a champ that really doesn't need it, it totally stuffed me on a volley where I turned did the volley but had my cursor back to my direction I was trying to run in. I also felt it caused lag in the actual actions when playing.
Using an extra key is not an option for me - just can't get to the shift keyas well do its remap totally or not
Just keep using it until you're used to it. I changed all the ability keys to smart cast and IMO it makes it much easier to control your character. The only negative I've found is that you have to then learn all the spell ranges.
