Boys & Girls,
it's time for This Week Only. We have price reductions on selected items which will aid you towards building your dream PC, whilst saving you money. Take a look through the range!
ADATA S510 120GB SATA 6Gb/s Solid State Drive - Retail with Acronis True Image @ £115.99 inc VAT
The S510 is a highly cost-effective option for SSD upgrades of existing systems, and for new SATA 6Gb/s enabled computers. The S510 utilizes the new generation SandForce SF-2200 series controller, with native support for the SATA 6Gb/s platform. In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience. The S510 can reach 550/510MB read and write speeds respectively, with 4K random write speeds as high as 85,000 IOPS.
Superior to Mechanical Drives on all Fronts
Solid state drives require no defragmentation, and support the Windows TRIM command. The S510 provides vibration-free running and low power consumption, while taking full advantage of the 6Gb bandwidth transmission capability.
What is the Windows TRIM command optimizing component?
If your computer is running the Windows 7 operating system, the Windows TRIM optimization command can directly delete stored data in the Flash memory and release unused space (Free Blocks) to be used for system writes immediately. This results in more accelerated transfer and write performance for solid state drives, and is also effective in slowing down efficiency decline and depletion chances, maintaining effective operation and extending the life of the disk.
Powerful and Free Software Solution to Eliminate Reinstalls
All purchasers of the S510 can download the free Disk Migration Utility software. It facilitates the quick transfer of all files to the new solid state drive, significantly reducing the troublesome and time-consuming process of reinstalling software and restoring data from backups.
* Disk Migration Utility software runs on these operating systems: Windows XP / Windows Vista / Windows 7
Software Download Area: http://www.adata-group.com/index.php?action=ss_main&page=ss_software_5
- Capcity: 120GB
- Read: Up to 550MB/S
- Write: Up to 510MB/S
- Seq Read: Up to 200MB/S
- Seq Write: Up to 140MB/S
- 4K Random Write (Aligned): 60,000 IOPS
- Maximum 4K Randdom Write: 85,000 IOPS
- Sandforce SF-2281
Included in the box
- SSD 2.5" to 3.5" adaptor in metalic blue
- Mounting screws
- Code to download Acronis True Image
Was £119.99 Inc. VAT
Only £115.99 inc VAT.
ORDER NOW
ADATA S511 120GB SATA 6Gb/s Solid State Drive - Retail with Acronis True Image @ £133.99 inc VAT
The S511 utilizes the new generation SandForce SF-2200 series controller, with native support for the SATA 6Gb/s platform. The S511 completely brings into play the revolutionary high-speed performance of solid state drives, embracing a new world of transfer performance. With read and write speeds twice that of SSDs using the older SATA II specification, the S511 reached 550/520MB read and write speeds respectively, with 4K random write speeds as high as 85,000 IOPS in real world testing. This means transferring a 5GB video file can be completed in as few as 15 seconds. In actual testing of Windows 7 boot speed, the S511 clocked an impressive 21 second system boot time, giving full satisfaction to the performance needs of power users.
High-speed read and write performance enhances computing efficiency
Currently, the major processor platforms are gradually making the changeover to native SATA 6Gb/s chips. However, traditional mechanical drives are not capable of the corresponding high-speed read and write tasks. The result is that some newly-purchased computers can only utilize a fraction of the performance available when equipped with a traditional hard drive. The S511 solid state drive provides vibration-free running and low power consumption while taking full advantage of the 6Gb bandwidth transmission capability. In both desktop and laptop computers, and in a broad range of computing environments, SSDs built to the latest specification an irreplaceable advantage.
Solid state drives are the best choice when buying a new computer
With the increasing popularity of computing with the use of more diverse applications, computational speed has become a major consideration when buying computers. In video editing, large picture retouching, and computer drafting, reading and writing operations rely on fast and stable data storage.
The S511 adopts specially selected Flash chips from reliable manufacturers, and supports the Windows TRIM command. In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience.
System backup tools, eliminating installation operating procedures
All purchasers of the S511 can download the free Disk Migration Utility software. It facilitates the quick transfer of all files to the new solid state drive, significantly reducing the troublesome and time-consuming process of reinstalling software and restoring data from backups.
- Capcity: 120GB
- Maximum 4K Random Write: 85,000 IOPS
- Sandforce SF-2281
Included in the box
- Mounting screws
Was £139.99 Inc. VAT
Only £133.99 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £1.99 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £3.98 Inc. VAT
Only £1.99 inc VAT.
ORDER NOW
Intel Celeron G530 2.40GHz Socket LGA 1155 Processor - Retail @ £29.99 inc VAT
The Intel Celeron processor is designed to bring a balanced level of proven technology and value to basic PC desktops. With the Celeron processor you can expect an affordable and reliable PC for your home or home office to meet your basic computing needs, such as e-mailing friends and relatives, tracking home finances, and running interactive or educational software for your kids. It provides great balance between computing power and affordability. The entire family of Celeron processors delivers Intel technology, quality, and reliability to the desktop, value PC consumer.
- Socket 1155
- Dual Core
- 2.40GHz
- 2MB Smart Cache
- GPU 650Mhz
- Thermals 35W
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Intel Pentium G620 2.60GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £45.59 inc VAT
Intel Pentium G620, Socket 1155, Dual Core, 2.60GHz, 3MB Smart Cache, GPU 850Mhz, 65W, Retail
Was £47.99 Inc. VAT
Only £45.59 inc VAT.
ORDER NOW
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £89.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming.
- Not compatible with Socket LGA1156 Mainboards!!
- Lithography Process: 32 nm
- Cores: 2
- Threads: 4
- Frequency: 3.10 GHz
- Integrated HD 2000 Graphics
- Integrated Graphics Frequency: 850MHz
- Cache: 3 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 65W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £167.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £179.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £239.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £253.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £257.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £455.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 K series with unlocked multiplier. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.20GHz (3.80GHz TURBO)
- Multiplier: 32x (Upto 40x available)
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- TDP: 130W
- DOES NOT INCLUDE COOLER
- 3yr Warranty
Was £499.99 Inc. VAT
Only £455.99 inc VAT.
ORDER NOW
Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £779.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.30GHz (3.90GHz TURBO)
- Multiplier: 33x (Unlocked Multiplier)
- L3 Cache: 15MB
- TDP: 130W
- 3yr Warranty
Was £849.95 Inc. VAT
Only £779.99 inc VAT.
ORDER NOW
AMD Llano A8-3870K 3.00GHz (Socket FM1) APU Processor (AD3870WNGXBOX) @ £105.59 inc VAT
Systems powered by AMD A-Series APUs with discrete-level graphics deliver up to 3X the visual performance of competing Intel Systems. Boost visual performance by at least 120% when you combine an AMD A-Series APU with select AMD Radeon™ HD 6000 Series graphics cards. AMD Turbo CORE Technology dynamically adjusts to users’ various workloads, delivering up to 300MHz of additional frequency on select AMD A-Series APUs. The APU Enables the graphics features and performance users demand with full DirectX®11 support.
Features:-
- Highly overclockable
- Socket FM1
- 4MB Cache
- 4 Cores
- 3000MHz CPU Clock
- 400 Radeon Cores
- 600MHz GPU Clock
- Max DDR3 2133MHz
- Dual Graphics Yes
- Warranty: 3yr
Was £109.99 Inc. VAT
Only £105.59 inc VAT.
ORDER NOW
AMD Llano A6-3670K 2.70GHz (Socket FM1) APU Processor (AD3670WNGXBOX) @ £83.99 inc VAT
Features:-
- Socket FM1
- 4MB Cache
- 4 Cores
- 2700MHz CPU Clock
- 400 Radeon Cores
- 600MHz GPU Clock
- Max DDR3 2133MHz
- Dual Graphics Yes
- Warranty: 3yr
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
AMD Llano A4-3300 2.50GHz (Socket FM1) APU Processor (AD3300OJGXBOX) @ £47.99 inc VAT
The AMD Fusion family of Accelerated Processing Units (APUs) is coming. Working in conjunction with the advanced x86 processor cores, an APUs multiple vector cores enable software developers to create innovative new applications that expand usage models and make PCs fast, easy to use, and more intuitive. The recent introduction of new tools for thread-level and data-parallel applications development simplifies the task of creating these applications. The development platforms and tools are scheduled to be widely available. The rest is up to entrepreneurial developers and PC manufacturers.
- Socket FM1
- 1MB Cache
- 2 Cores
- 2500MHz CPU Clock
- 240 Radeon Cores
- 443MHz GPU Clock
- Max DDR3 1600MHz
- Dual Graphics Yes
Was £49.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £191.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.60GHz Clock Speed
- 4.20GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.9375v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Was £199.99 Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8120 Black Edition 3.10Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £155.99 inc VAT
- 3.10GHz Clock Speed
- 4.00GHz Turbo Clock Speed
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.975v - 1.4125v
- 32nm technology
- 3 Year Warranty
Was £157.99 Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £83.99 inc VAT
We call it the new AMD FX 4-Core Processor Black Edition and it's unlocked for your overclocking pleasure. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Quad Core Technology
- 3.80GHz Turbo Clock Speed
- AM3+ Socket
- 4MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 95W
- Voltage: 0.925v - 1.4125v
- 32nm technology
- 3 Year Warranty
Was £94.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/12GX) @ £53.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (4GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £56.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair Vengeance RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (CMZ8GX3M2A2133C11R) @ £95.99 inc VAT
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. As a bonus, the attractive low price of Vengeance memory will also leave lots of room in your system build budget. Now available in Racing Red
Vengeance memory is designed specifically for the latest CPUs. Vengeance modules run at 1.5V for maximum compatibility with all Intel® Core™ i3, i5 and i7 processors, as well as the 2nd generation Intel processor family. Vengeance DDR3 memory is available in single modules, and two or three module kits, making it easy for you to match the DIMM population requirements of your motherboard.
Most Vengeance DIMMs are built with two gigabit RAM ICs. These extra-dense memory chips allow you to have 8GB of memory using only two DIMMs, or to populate your triple channel system with up to an insanely large 24GB of system memory for extreme multitasking performance.
Features:-
- Each two module set is tested at 2133MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 11-11-11-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 11-11-11-27 values at 2133MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 2133MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £99.95 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £53.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1600MHz, 1.50V
- 100% tested at 1600MHz in Intel based motherboards
- Lifetime Warranty
Was £59.99 Inc. VAT
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) @ £53.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-10-9-27 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £59.99 Inc. VAT
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX8GX3M2A2000C9) @ £59.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Two matched 2GB modules for use in high performance Intel Core i7, i5, and i3 dual channel processors
- Outrageously fast 2000MHz performance using 4GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 8GB (2x4GB Module)
- Pin Voltage: 1.50-1.65V
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX4GX3M2B2000C9) @ £35.99 inc VAT
- Density: 4GB (2x2GB Module)
Was £39.95 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit @ £299.99 inc VAT
Team Xtreem LV DDR3 2600 Quad-Channel CL10 uses selected chips and passes 100% stringent testing. 2600 MHz speed rate with 20,800MB/sec transmission bandwidth and covered in the super slim aluminum heat sink, to lift the transmission speed and quality steadiness to another level.
It is the only one to meet the extremely high standards of the 1T Command rate in the market, and its efficiency is 10% better than any other Quad-Channel memory!
Team Xtreem LV DDR3 2600 Quad-Channel is designated to exceed enthusiast’s high expectations by bringing them the ultimate OC experience.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth 20,800 MB/Sec (PC3 20,800)
- CL-value: 10-12-12-31 1T
- Working voltage: 1.55-1.65V
- PCB: 8 layer PCB
Was £319.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) @ £131.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
Was £149.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £35.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- Lifetime Warranty
Was £39.95 Inc. VAT
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £35.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Was £43.99 Inc. VAT
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £47.99 inc VAT
nonl2br
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.<br /><br />
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.<br /><br />
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
<br /><br />
Features:-<br />
- Black PCB<br />
- Black high performance CAMO ALU heatspreaders<br />
- Ultimate performance memory<br />
- Activity LED's (RED / GREEN)<br />
- Temperature Probe<br />
- Crucial MOD software compatible<br />
- Each two module set is tested at 1600MHz<br />
- Tactical heat spreader for performance<br />
- Packaged together immediately following system test<br />
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.<br />
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.<br />
- XMP 8-8-8-24 values at 1600MHz, 1.50V<br />
- 8192 Megabytes of DDR3 memory<br />
- Two matched 4GB modules<br />
- 100% tested at 1600MHz in Intel based motherboards<br />
- Supports Intel Extreme Memory Profiles (XMP)<br />
- Lifetime Warranty<br />
- Sandybridge compatible<br />
- Bulldozer compatible<br /><br />
<iframe width="640" height="360" src="
" frameborder="0" allowfullscreen></iframe>
Was £59.99 Inc. VAT
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £47.99 inc VAT
nonl2br
<br /><br />
Features:-<br />
- Black PCB<br />
- Activity LED's (ORANGE & BLUE)<br />
Was £59.99 Inc. VAT
ORDER NOW
Crucial 4GB (1x4GB) DDR3 PC3-10600C9 1333MHz 204-Pin SODIMM Module (CT51264BC1339) @ £17.99 inc VAT
The incorporation of DDR3 memory now extends beyond desktop systems to laptops, offering increased frequencies at lower voltage requirements. Crucials’s PC3-10666 SODIMM kits support blazing speeds and bring frequencies to notebook systems that were previously unimaginable. Gamers, enthusiasts, and business professionals will benefit from the greater overall computing experience that these new high-density, high speed modules have to offer their next generation system. Crucial PC3-10666 SODIMM modules will feature 9-9-9-24 timings at low 1.5V to keep power consumption at minimum levels. Maximized productivity with the latest games, programs, and operating systems. Crucial's DDR3 SODIMMs are built to provide optimal compatibility using the highest quality components screened out using the most sophisticated testing available to deliver exceptional system performance.
- 1333MHz DDR3
- CL 9-9-9-24
- Unbuffered
- 1.5 Volts
- Lifetime Warranty
- 204 Pin DIMM
- Apple IMac Compatible (Please check http://support.apple.com/kb/HT1423)
Was £20.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 7950 3072MB PCI-Express Graphics Card @ £347.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was £353.99 Inc. VAT
Only £347.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 7950 OC 3072MB PCI-Express Graphics Card (11196-02-40G) @ £395.99 inc VAT
- Core Clock: 900MHz
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £399.95 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £214.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6970 IceQ Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £269.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 900MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1400MHz (5.6Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Memory Clock: 5600MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Only £269.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6970 2048MB Twin Frozr III GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
This special Twin Frozr III Edition utilises the same PCB from the flagship lightning cards and as such has both performance and silent modes. With the amazing Twin Frozr III cooler for near silent operation, cooler running and great overclocking potential. There is no better value 6970 on the market!
Features:-
- Same PCB / Components as Lightning Version
- Huge overclocking potential (1000MHz+ Core possible though not guaranteed)
- Near Silent Operation
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Texture Units: 96
- ROPS: 32
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £275.99 Inc. VAT
ORDER NOW
MSI ATI Radeon HD 6970 OC Lightning 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £275.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/AMDLightningStatic.jpg" alt="MSI Lightning" /><br>
<br>
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records! <br>
<br>
<Font size="5"><b>Key Features</b></font><br>
<br>
<img src="http://marketing-uk.msi.com/images/power4.png" width="210" align="left" alt="power4" /><b>Industry-leading Power4 Architecture for Overclocking Reliability</b><br>
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there. <br>
<br>
<img src="http://marketing-uk.msi.com/images/lightningsplit.png" width="210" align="right" alt="Cooling" />
<br>
<b>Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level</b><br>
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.<br>
<br>
<img src="http://marketing-uk.msi.com/images/afterburner.png" align="left" alt="afterburner" /><br>
<b>Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage</b><br>
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
<b>King of Extreme Overclocking</b><br>
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking<br>
<br>
<img src="http://marketing-uk.msi.com/images/mcii.png" align="right" alt="Military Class" /><b>Carefully Selected Materials</b><br>
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
<br>
<br>
<img src="http://marketing-uk.msi.com/images/MUSTHAVE.png" alt="Kit Guru Gold" /><img src="http://www.vortez.co.uk/contentteller.php?ct=content&action=file&id=21" width="200" alt="vORTEZ Gold" />
<br>
<br>
<Font size="5"><b>Specifications</b></font><br>
<br>
<b>Stream Processors</b> - 1536 Units<br>
<b>Core Clock</b> - 940 MHz<br>
<b>Memory Clock</b> - 5500 MHz<br>
<b>Memory Size</b> - 2048MB GDDR5<br>
<b>Memory Bus</b> - 256 bits<br>
<b>Output</b> - Mini DisplayPort*2 / HDMI / DVI*2<br>
<b>TDP</b> - 269 W<br>
<b>Card Dimension</b> - 310x127x40mm<br>
<b>Form Factor</b> - ATX<br>
<b>DirectX 11</b> - Y<br>
<b>OpenGL 4.0</b> - Y<br>
<b>CrossFireX</b> - Y<br>
<b>Eyefinity</b> - Y<br>
<b>AVIVO HD</b> - Y<br>
<b>PowerPlay</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
- World’s first 18 phase PWM on HD 6970.<br>
- Independent Memory Power support. <br>
- Copper MOS with 2x high current capacity. <br>
- Proadlizer*4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter. <br>
- Propeller Blade technology for 20% more airflow. <br>
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation. <br>
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- Support voltage adjustment of GPU/Memory/VDDCI<br>
- Military Class II Components for longer product lifespan. <br>
- LPL (Lightning Power Layer) for the stable power supply.<br>
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!<br>
<br>
<b>- Now with Three Year Warranty</b><br>
<img src="http://emm.msi.com/admin/temp/newsletters/1226/3yearfinal.jpg" width="250" alt="3 year warranty" /><br>
Was £299.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £209.99 inc VAT
The SAPPHIRE HD 6950 Dirt3 Special Edition is a new SAPPHIRE original model with a special cooler using a new dual fan configuration. Based on the latest high end AMD GPU architecture, it boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speed of 800MHz for the core and 2GB of the latest GDDR5 memory running at 1250Mhz (5 Gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS settings and performance can be further enhanced with the SAPPHIRE overclocking tool, TriXX, available as a free download from http://www.sapphiretech.com/ssc/TriXX/
Features:-
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 x Dual-Link DVI-I, 1 x Single-Link DVI-D, 1 x HDMI, 1 x DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- Warranty: 2 Years
Was £219.95 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card with FREE BattleField 3 PC Game @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tessellation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Memory Interface: 256-Bit
- Display Connectors: 1x Dual-Link DVI, 1x Single-Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- OpenGL 4.1 Support
- ATI Avivo HD
- Warranty: 2 Years
- BF3 Game
Was £269.99 Inc. VAT
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £124.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
The SAPPHIRE HD 6800 series features the second generation of graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
- Core Clock: 775MHz
- Memory Clock: 4000MHz (Effective)
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with DIRT3 Full PC Game download code (subject to availability)
ORDER NOW
XFX ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card @ £125.99 inc VAT
- Memory Clock: 4200MHz (Effective)
- Processing Cores: 1120
- Display Connectors: 1 Dual Link DVI and 1 Single Link DVI, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £137.99 Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £101.99 Inc. VAT
ORDER NOW
Asus ATI Radeon HD 6770 1024MB GDDR5 PCI-Express Graphics Card @ £76.79 inc VAT
Now, more people than ever can experience real innovation in DirectX® 11 gaming with AMD Radeon™ HD 6770 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
Precision mounted DirectCU copper heatpipes in direct contact with the GPU for rapid heat dissipation – creating 20%* cooler and quiet performance in idle.
Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan.
Unique fan design dissipates heat efficiently while extending a graphic card’s lifespan by 25%* through increased dust and particle resistance. Intelligent system monitoring for efficient overclocking with an intuitive slide bar. Real-time overclocking, benchmarking and video capturing in any PC game!
Features:-
- DirectCU copper heat pipes directly contact with the GPU for rapid heat dissipation for 20%* cooler operation compared to reference
- Pump up graphics performance with Super Alloy Power that delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- DirectX 11® brings new levels of visual realism to gaming on the PC
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI 1.4a & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- 3yr Warranty
Was £84.95 Inc. VAT
Only £76.79 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6670 "Ultimate Edition"1024MB GDDR5 PCI-Express Graphics Card @ £71.99 inc VAT
The SAPPHIRE HD 6670 ULTIMATE Edition delivers new gaming experiences and acceleration of next generation high performance applications yet runs totally silently. All of this comes with low active power consumption and Dynamic Power Management delivering super low-power operation in 2D or idle. As the core technology is low power, no external power connection is required, making this series ideal for system upgrades or mainstream PCs that do not have high end power supplies.
Features:-
- SILENT DESIGN
- Processing Cores: 480
- HDCP Capable
- ATI Avivo HD
- Dimension 164(W) x40(W)x 107(H) mm Size.
- Warranty: 2 Years
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6670 2048MB GDDR3 PCI-Express Graphics Card @ £55.19 inc VAT
The AMD Radeon HD 6670 graphics processors offer advanced video and display features, as well as AMD's 2nd generation support for DirectXR 11 to give you the ultimate in "visual immersion" for your PC.
- D-Sub(VGA);
- Dual-Link DVI;
- HDMI 1.4a;
- 40nm Process Technology;
- Hyper Memory Support;
- AMD Avivo HD (DVD/HD-DVD/Blu-ray Playback);
- PCI-Express 2.0;
- AMD HD3D Technology;
- Microsoft DirectX 11;
- OpenGL 4.1;
- Shader Model 5.0;
- AMD Catalyst Control Center;
- Accelerated Video Transcoding;
- Dolby TrueHD and DTSHD Master Audio Support;
- Enhanced Unified Video Decoder 3 (UVD 3);
- Enhanced Internet Browser Applications;
- Windows 7 support;
- AMD App Acceleration;
- 2 Years Manufacturers Warranty;
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6570 HM 1024MB GDDR3 PCI-Express Graphics Card (11191-01-20G) @ £45.59 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6570 graphics processors offer advanced video and display features, HDMI 1.4a for stereoscopic (3D) displays, as well as 2nd generation support for DirectX 11 to offer the ultimate in versatility for the everyday computing desktop.
- Core Clock: 650MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1800MHz (Effective)
- HDCP Capable
- ATI Avivo HD
- Dimension 169(L) x 19(W)x94(H) mm Size.
- Warranty: 2 Years
Was £49.99 Inc. VAT
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card @ £21.59 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Memory: 512MB GDDR3
- Memory Interface: 64-Bit
- Memory Clock: 1066MHz (Effective)
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was £23.99 Inc. VAT
Only £21.59 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £347.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
- Supplied with FREE Mafia 2 PC Game Download Code (Subject to availability)
Was £359.99 Inc. VAT
ORDER NOW
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £455.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £469.99 Inc. VAT
ORDER NOW
OcUK GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £335.99 inc VAT
Features:-
- Core Clock: 772MHz (Fermi GF110)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £349.99 Inc. VAT
Only £335.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £257.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/PowerEdition.jpg" alt="Power Edition" /><br>
<br>
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
<Font size="4"><b>Key Features</b><br></font>
<b>Propeller Blade on Twin Frozr III</b><br>
- Twin Frozr III Thermal Design with 18C cooler & 7.7 dB quieter.<br>
- Propeller Blade technology for 20% more airflow.<br>
- Dual 8cm fans with dual 8mm SuperPipes for best heat dissipation.<br>
<br>
<b>Power Edition Architecture</b><br>
- Triple overvoltage function support by MSI Afterburner to raise overclock capability.<br>
- 6+1 Phase PWM Design provides better overclock stability.<br>
<br>
<b>MSI Exclusive P/S Switch Function</b><br>
- Dual fan speed profiles–Performance/Silent.<br>
- Performance Mode provides best cooling demand; Silent Mode balances noise and GPU Temperature.<br>
<br>
<b>Military Class II Components</b><br>
- SFC (Super Ferrite Choke) has higher current for better overclocking ability.<br>
- Hi-C CAP for GPU provides more precise voltage.<br>
- All Solid CAPs have longer lifespan.<br>
<br>
<Font size="4"><b>Specification</b><br></font>
- Core Clock: 770MHz <br>
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)<br>
- Memory: 1280MB GDDR5<br>
- Memory Clock: 4000MHz (Effective)<br>
- Memory Interface: 320-Bit<br>
- Processing Cores: 480<br>
- Shader Clock: 1540MHz<br>
- Bus Type: PCI-Express 2.0<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready (Upto 3-Way SLI Supported)<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 4.0 Support<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
- 3D Vision Enabled<br>
- NVIDIA Surround Enabled<br>
- Warranty: 3 years<br>
ORDER NOW
Asus GeForce GTX 560 DirectCU 1024MB GDDR5 PCI-Express Graphics Card @ £137.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Processing Cores: 336
- Shader Clock: 1620MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Only £137.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card @ £165.59 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 830MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 830MHz
- Processing Cores: 384
- Shader Clock: 1660MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £169.99 Inc. VAT
Only £165.59 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/560tfiibannerawards.jpg" width="768" alt="Hawk" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>Twin Frozr II Thermal Design 20 Degrees Celsuis Cooler!!</b><br>
- Dual 8CM PWM Fans for 50% more air alow can cool down GPU/Memory/Power Module at once.<br>
- Four heat pipes with SuperPipe Technology<br>
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.<br>
<img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf01.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf02.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf03.jpg" align="centre" width="220" alt="Triple Over Voltage" /><br>
<br>
<b>7+1 Phase PWM Design</b><br>
- Higher current to GPU Powerv
- Higher overclocking capability<br>
- Better stability in peak load <br>
<br>
<b>Military Class Components</b><br>
- Hi-C Cap provides more precise GPU voltage.<br>
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.<br>
- All Solid CAP for longer lifespan. <br>
<br>
<img src="http://eu.msi.com/pic/feature/features_20091001175702.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s113_20080924184632.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s114_20080924184756.gif" align="left" alt="MSI" />
<img src="http://www.msi.com/pic/feature/features_20101116171850.jpg" align="left" alt="MSI" /><br>
<br>
<br>
<br>
<br>
<br>
<BR>
<BR>
<br>
<font size="4"><b>Specifications</b></font><br><br>
- Dual 8cm PWM Fans for 50% more airflow.<br>
- Superpipe technology and nickel-plated copper base for better dissipation<br>
- 20c cooler than reference design<br>
- Military Class II Components<br>
- Core Clock: 880MHz <br>
- Memory: 1024MB GDDR5<br>
- Memory Clock: 4200MHz (Effective)<br>
- Memory Interface: 256-Bit<br>
- Processing Cores: 384<br>
- Shader Clock: 1760MHz<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready <br>
- HDCP Capable<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
<br>
Only £173.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 560Ti 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
With 2X memory size, Palit GeForce® GTX 560 Ti 2GB support better performance at maximum resolution monitor while GPU works alongside the CPU to drive fantastic graphics performance. You can enjoy the extreme performance while playing the latest DX10/DX11 PC games under HD large screen with Palit GeForce® GTX 560 Ti 2GB.
Features:-
- Core Clock: 822MHz
- Shader Clock: 1645MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
- Upto 220% faster than 1GB version in BF3: http://forums.overclockers.co.uk/showthread.php?t=18344290
Was £215.99 Inc. VAT
ORDER NOW
OcUK GeForce GT 520 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £29.99 inc VAT
Make your video experience better. Whether you stream 1080p online videos from sites like YouTube® or Hulu® or prefer immersive Blu-Ray 3D™ movies, the power of the GeForce® GT 520 GPU makes your video playback fast and smooth.
In addition to rendering your high-res photos instantly, the GeForce® GT 520 also speeds up the editing of your videos. And when you share your photos and videos online, you'll enjoy a richer web experience with GPU accelerated browsers like Google Chrome™ and Internet Explorer® 9.
Go beyond photos and videos and take your gaming to the next level. With the GeForce® GT 520, your favourite DirectX11 games come to life with lifelike characters and incredibly detailed terrain and game environments.
Features:-
- Core clock: 810Mhz
- 1x HDMI
- 1x Analogue
- 1x Dual-Link DVI
- DirectX Version: 11
- OpenGL Version: 4
- SLI Support
- Warranty: 2 Years
Was £32.99 Inc. VAT
ORDER NOW
OcUK GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675MHz
- Memory Clock: 3600MHz (Effective)
- Shader Clock: 1350MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.3a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £99.95 Inc. VAT
ORDER NOW
Asus GeForce GT 440 SILENT 1024MB GDDR3 PCI-Express Graphics Card @ £53.99 inc VAT
NVIDIA® GeForce® GT 440 is the performance boost your PC needs to GPU accelerate the editing of your photos and HD videos, watch Blu-Ray 3D movies and play hot PC games on the latest DirectX 11 titles like Civilization V. Equipped with the latest industry leading technologies including NVIDIA® PhysX®, NVIDIA® CUDA™, high performance NVIDIA GeForce drivers, and more, GeForce GT 440 has everything you need to accelerate your digital life.
The flattened copper heat-pipe contacts GPU directly for 0dB cooling experience.
Specification:-
- Effective and quiet DirectCU Silent 0dB thermal design
- SILENT DESIGN
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £56.99 Inc. VAT
ORDER NOW
Gigabyte GeForce GT 430 OC "Dual Fan" 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £47.99 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 730MHz
- Shader Clock: 1460MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Warranty: 2 Years
Was £53.99 Inc. VAT
ORDER NOW
OcUK GeForce GT 430 1024MB GDDR3 PCI-Express Graphics Card @ £35.99 inc VAT
Specification:-
- Core Clock: 700MHz
- Memory Clock: 1600MHz (Effective)
- Shader Clock: 1400MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £43.99 Inc. VAT
ORDER NOW
MSI GeForce N210 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £21.59 inc VAT
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them to Facebook up to 50% faster with the GeForce 210. Convert your video and put it on your iPod in minutes instead of hours or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-Ray Movies? It doesn’t matter, the GeForce 210 can playback any Blu Ray Movie with any modern CPU.
- Core Clock: 589MHz
- Memory Clock: 1000MHz (Effective)
- Processing Cores: 16
- Shader Clock: 1178MHz
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 2 Years
Was £23.99 Inc. VAT
ORDER NOW
BenQ G925HDA 18.5" Widescreen LCD Monitor - Black @ £65.99 inc VAT
The BenQ G925HDA is built to broaden your view with 18.5“W 16:9 LCD display! The best part is it’s also energy efficient, reducing power consumption by 23.3% in comparing to previous model.
5ms response time means that even highly dynamic video is rendered fluidly without ghosting or other artifacts.
With a dynamic contrast ratio of 40000:1 to give you splendid image details and clarity in darkened and complex motion pictures, everything becomes more vivid!
BenQ’s exclusive Senseye®+Photo Technology gives you preset modes—Standard, Dynamic, Movie, Photo—that provide instant optimized settings for different usage scenarios. Senseye®+Photo is an enhanced version that adds support for the industry-standard sRGB color space, allowing you to obtain consistent results when you view and manipulate images on the G925HDA and on other sRGB-compliant devices.
This mode allows aspect ratio’s other 16:9 to be displayed without geometric distortion. So, it can perfectly display a full picture with its 16:9 widescreen panel – allowing you to enjoy the best visual entertainment.
Features
- Screen Size: 18.5" Wide
- Resolution (max.): 1366 x 768
- Pixel Pitch: 0.3 mm
- Brightness: 200 cd/m²
- Contrast Ratio: 700:1
- Dynamic Contrast Ratio: 40,000:1
- Response Time: (tr/tf) 5ms
- Display Area: 409.8 x 230.4 mm
- Display Color: 16.7 million
- Viewing Angle: (L/R;U/D) (CR>=10) 90 / 65
- Terminals: D-sub
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 110
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 23W (on mode)
- Auto Switching Power Supply Built-in
- Power Saving Mode <1W
- Senseye+Photo Technology
- HDCP Support: NO
- Adjustments Tilt: -5 / 20 (down / up)
- Dimensions (HxWxD): 345.8 x 444.4 x 165 mm
- with wall mount: 278.8 x 444.4 x 62.1 mm
- Weight: Net 2.8 kg / Gross 4.3 kg
- Accessories (Standard): VGA cable / Power cable
- Warranty: 2yrs
Was £73.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Iiyama ProLite P1705S-B 17" Hard Glass LCD Monitor - Black @ £95.99 inc VAT
The ProLite P1705S meets the increasing demands for Protected LCD’s within Education, Retail and Industrial applications. In addition to having toughened safety glass fitted behind the bezel at 8H hardness rating capable of resisting above normal impacts to the display, iiyama have enhanced the range to include the latest high performance and energy saving technology. Features include 5msec response time, 1000:1 contrast ratio enhancing colour and Analogue and DVI inputs. The displays are Energy Star rated and have 19W typical power consumption in use and less than 1W in standby.
All iiyama monitors are compatible with Apple-Macintosh computers.
Main Features:
- Iiyama ProLite P1705S-1 Monitor
- 17 inch (43cm) TFT LCD Screen Size
- Glass hardness: 8H minimum
- Native resolution: 1280 x 1024 (SXGA)
- Contrast ratio 1000 : 1 typical
- Brightness 250 cd / m2 typical
- Response time: 5 msec
- Input connector: DVI-D, D-Sub
- 2 x 1W Speakers
- Kensington-lock prepared
- Colour: Black
Was £104.99 Inc. VAT
ORDER NOW
Dell IN2020N 20" Widescreen LCD Monitor - Black @ £79.99 inc VAT
Enhance your multimedia experience with the IN2020 high-definition monitor with LED. This 20" widescreen display offers brilliantly vivid features at an even more brilliant price.
Highlights of the Dell 20" Wide IN2020N 5ms LED HD
* Enhance your multimedia view
* Environmental footprint
* Convenient comfort
* Great-value performance
Expand your productivity and multimedia performance with this 20" widescreen display, including LED backlight. With its 16:9 aspect ratio, 8,000,000:1 high dynamic contrast ratio and 1600 x 900 high-definition display, the IN2020 is excellent for viewing movies, photos and videos. Plus, you'll never skip a beat by adding the optional multimedia Dell soundbar for an enhanced audio experience.
The IN2020 monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, Energy Star 5.0, to help you lower energy consumption without sacrificing performance.
Convenient comfort
The IN2020 monitor is uniquely designed for comfort, convenience and visual appeal. With tilt adjustability, the IN2020 offers a versatile and comfortable view. The high-gloss slim black bezel complements both your home environment and your Dell desktop or laptop. Simply connect to any standard computer using the VGA connector.
The IN2020 monitor delivers a high dynamic contrast ratio of 8,000,000:1, vivid 1600 x 900 high-definition resolution, a fast response time and VGA connectivity, all at an affordable price.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 1000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 160°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- Dimensions: 453.7mm x 344.0mm x 204.8mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was £85.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Iiyama ProLite E2008HDS 20" Widescreen LCD Monitor - Black @ £89.99 inc VAT
The Iiyama E2008HDS-1 20" LCD offers great value for money, and is the ideal screen for Gaming or as a Home Office display. Iiyama’s Opti-Colour Modes ensure high colour performance, supported by an ultra fast 2ms response time and a high 1600x900 resolution. With DVI and VGA connections and Iiyama’s new Power Saving Eco Modes, you are in safe hands with this superb display.
- Contrast Ratio: 30000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 485.0mm x 367.0mm x 193.0mm
- VESA Compliant
- Weight: 4.0kg
- Stereo Speakers
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
NVIDIA 3D Vision Kit with Duke Nukem Forever @ £79.99 inc VAT
Upgrade your PC to a fully immersive stereoscopic 3D experience with Nvidia GeForce 3D Vision. A combination of high-tech wireless glasses and advanced software, GeForce 3D Vision automatically transforms hundreds of PC games into full stereoscopic 3D. Just slip on the stylish glasses and pair them with an Nvidia GeForce GPU and a "GeForce 3D Vision-Ready" display to experience characters and environments come to life on the screen. In addition, you can watch 3D movies and 3D digital photographs in eye popping, crystal-clear quality. Give your eyes something to talk about with GeForce 3D Vision. Requires 120Hz Monitor.
- Convert standard games into stereoscopic 3D
- Highest quality stereoscopic 3D solution
- Designed for comfort and style
- Wear over your prescription glasses
- High power wireless infrared communication
- Game for more than forty hours on a single charge
- Adjust 3D depth adjustment from the IR emitter
- Watch movies in 3D
- Stereoscopic 3D picture support
- Supplied with Duke Nukem Forever Full Game Download
NOTE: Requires 120Hz Monitor
NOTE: Requires Nvidia GeForce 8800 GTX or above Graphics Card
Was £113.99 Inc. VAT
ORDER NOW
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black @ £99.98 inc VAT
The ProLite E2208HDD Widescreen LCD features true High Definition, 16:9, 1920 x 1080 pixels as its native resolution. Impressive colour reproduction is achieved with a typical contrast ratio of 1000:1 with the User Option to enhance further with Advanced Contrast Ratio enabled for 10000:1. 'Opticolour' automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 170°/160°
- VESA Compliant
- Dimensions: 516.5mm x 386.0mm x 193.0mm
- Weight: 4.2kg
Was £119.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Contrast Ratio: 5000000:1
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
Was £134.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
OcUK E2250SWDA 22" Widescreen LED Monitor - Black @ £79.99 inc VAT
The OcUK 22" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 20,000,000:1 contrast ratio and digital connectivity there is no other LED that can match the combination of value and performance.
Features
- Screen Size: 21.6" Widescreen
- Contrast Ratio: 20,000,000:1
- Multimedia Speakers
Was £89.99 Inc. VAT
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £179.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was £199.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black @ £149.99 inc VAT
ProLite X2377HDS - A 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all around panel type. This IPS panel offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2377HDS is full HD, has a 5 000,000:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user clear and vivid images. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The Prolite X2377HDS has two integrated stereo speakers and is VESA mount compatible. It will provide both excellent performance for photographic, design and web-design and is also an excellent choice for Universities, Corporate and Financial Markets, as well as the rapidly expanding demand for Multi Monitor applications.
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- Multimedia Stereo Speakers
- 3yr Warranty
Was £155.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £339.98 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was £379.99 Inc. VAT
Only £339.98 inc VAT.
ORDER NOW
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Contrast Ratio: 60000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £131.99 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Only £131.99 inc VAT.
ORDER NOW
IIyama Prolite E2473HDS 24" Widescreen LED Monitor - Black @ £149.99 inc VAT
The ProLite E2473HDS LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr On-site Warranty
Was £161.99 Inc. VAT
ORDER NOW
OcUK 2436VWA 24" Widescreen LCD Monitor - Black @ £119.99 inc VAT
The OcUK 24" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 60,000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
Features
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 60,000:1
- Colors: 16.7 M
- HDCP compatible: Yes
- USB: 1up / 1down
- VESA 100x100mm
Was £131.99 Inc. VAT
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £179.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- VESA Compliant
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £479.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- True Resolution : 1920x1080
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Earphone jack : 3.5mm Mini-Jack
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was £539.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Hazro HZ30Wie 10-Bit 30" LCD Widescreen Professional Monitor - Black @ £699.98 inc VAT
The Hazro HZ30Wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30Wi performs with consistency and clarity to optimise your visual experience. The Hazro HZ30Wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30Wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30Wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30Wi offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30Wi is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 3yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Was £719.99 Inc. VAT
Only £699.98 inc VAT.
ORDER NOW
Iiyama ProLite E2773HDS 27" Widescreen LED 1MS Monitor - Black @ £239.99 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
Features:
- LED Backlit
- Full HD
- ACR Capeablity
- Inbuilt Speakers
- HDMI Input
- Overdrive Feature
- VESA Mountable
- Compatible with Xbox 360 & PS3
Technical Specifications:
- Contrast Ratio: 5 000 000 : 1
- Response Time: 1ms
- VESA Compliant
- Adjustable Stand
- Weight: 5.3kg
Was £259.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
it's time for This Week Only. We have price reductions on selected items which will aid you towards building your dream PC, whilst saving you money. Take a look through the range!
ADATA S510 120GB SATA 6Gb/s Solid State Drive - Retail with Acronis True Image @ £115.99 inc VAT
The S510 is a highly cost-effective option for SSD upgrades of existing systems, and for new SATA 6Gb/s enabled computers. The S510 utilizes the new generation SandForce SF-2200 series controller, with native support for the SATA 6Gb/s platform. In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience. The S510 can reach 550/510MB read and write speeds respectively, with 4K random write speeds as high as 85,000 IOPS.
Superior to Mechanical Drives on all Fronts
Solid state drives require no defragmentation, and support the Windows TRIM command. The S510 provides vibration-free running and low power consumption, while taking full advantage of the 6Gb bandwidth transmission capability.
What is the Windows TRIM command optimizing component?
If your computer is running the Windows 7 operating system, the Windows TRIM optimization command can directly delete stored data in the Flash memory and release unused space (Free Blocks) to be used for system writes immediately. This results in more accelerated transfer and write performance for solid state drives, and is also effective in slowing down efficiency decline and depletion chances, maintaining effective operation and extending the life of the disk.
Powerful and Free Software Solution to Eliminate Reinstalls
All purchasers of the S510 can download the free Disk Migration Utility software. It facilitates the quick transfer of all files to the new solid state drive, significantly reducing the troublesome and time-consuming process of reinstalling software and restoring data from backups.
* Disk Migration Utility software runs on these operating systems: Windows XP / Windows Vista / Windows 7
Software Download Area: http://www.adata-group.com/index.php?action=ss_main&page=ss_software_5
- Capcity: 120GB
- Read: Up to 550MB/S
- Write: Up to 510MB/S
- Seq Read: Up to 200MB/S
- Seq Write: Up to 140MB/S
- 4K Random Write (Aligned): 60,000 IOPS
- Maximum 4K Randdom Write: 85,000 IOPS
- Sandforce SF-2281
Included in the box
- SSD 2.5" to 3.5" adaptor in metalic blue
- Mounting screws
- Code to download Acronis True Image
Only £115.99 inc VAT.
ORDER NOW
ADATA S511 120GB SATA 6Gb/s Solid State Drive - Retail with Acronis True Image @ £133.99 inc VAT
The S511 utilizes the new generation SandForce SF-2200 series controller, with native support for the SATA 6Gb/s platform. The S511 completely brings into play the revolutionary high-speed performance of solid state drives, embracing a new world of transfer performance. With read and write speeds twice that of SSDs using the older SATA II specification, the S511 reached 550/520MB read and write speeds respectively, with 4K random write speeds as high as 85,000 IOPS in real world testing. This means transferring a 5GB video file can be completed in as few as 15 seconds. In actual testing of Windows 7 boot speed, the S511 clocked an impressive 21 second system boot time, giving full satisfaction to the performance needs of power users.
High-speed read and write performance enhances computing efficiency
Currently, the major processor platforms are gradually making the changeover to native SATA 6Gb/s chips. However, traditional mechanical drives are not capable of the corresponding high-speed read and write tasks. The result is that some newly-purchased computers can only utilize a fraction of the performance available when equipped with a traditional hard drive. The S511 solid state drive provides vibration-free running and low power consumption while taking full advantage of the 6Gb bandwidth transmission capability. In both desktop and laptop computers, and in a broad range of computing environments, SSDs built to the latest specification an irreplaceable advantage.
Solid state drives are the best choice when buying a new computer
With the increasing popularity of computing with the use of more diverse applications, computational speed has become a major consideration when buying computers. In video editing, large picture retouching, and computer drafting, reading and writing operations rely on fast and stable data storage.
The S511 adopts specially selected Flash chips from reliable manufacturers, and supports the Windows TRIM command. In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience.
System backup tools, eliminating installation operating procedures
All purchasers of the S511 can download the free Disk Migration Utility software. It facilitates the quick transfer of all files to the new solid state drive, significantly reducing the troublesome and time-consuming process of reinstalling software and restoring data from backups.
- Capcity: 120GB
- Maximum 4K Random Write: 85,000 IOPS
- Sandforce SF-2281
Included in the box
- Mounting screws
Was £139.99 Inc. VAT
Only £133.99 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £1.99 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £3.98 Inc. VAT
Only £1.99 inc VAT.
ORDER NOW
Intel Celeron G530 2.40GHz Socket LGA 1155 Processor - Retail @ £29.99 inc VAT
The Intel Celeron processor is designed to bring a balanced level of proven technology and value to basic PC desktops. With the Celeron processor you can expect an affordable and reliable PC for your home or home office to meet your basic computing needs, such as e-mailing friends and relatives, tracking home finances, and running interactive or educational software for your kids. It provides great balance between computing power and affordability. The entire family of Celeron processors delivers Intel technology, quality, and reliability to the desktop, value PC consumer.
- Socket 1155
- Dual Core
- 2.40GHz
- 2MB Smart Cache
- GPU 650Mhz
- Thermals 35W
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Intel Pentium G620 2.60GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £45.59 inc VAT
Intel Pentium G620, Socket 1155, Dual Core, 2.60GHz, 3MB Smart Cache, GPU 850Mhz, 65W, Retail
Was £47.99 Inc. VAT
Only £45.59 inc VAT.
ORDER NOW
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £89.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming.
- Not compatible with Socket LGA1156 Mainboards!!
- Lithography Process: 32 nm
- Cores: 2
- Threads: 4
- Frequency: 3.10 GHz
- Integrated HD 2000 Graphics
- Integrated Graphics Frequency: 850MHz
- Cache: 3 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 65W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
Was £94.99 Inc. VAT
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £167.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £179.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £239.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £253.99 Inc. VAT
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £257.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £455.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 K series with unlocked multiplier. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.20GHz (3.80GHz TURBO)
- Multiplier: 32x (Upto 40x available)
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- TDP: 130W
- DOES NOT INCLUDE COOLER
- 3yr Warranty
Was £499.99 Inc. VAT
Only £455.99 inc VAT.
ORDER NOW
Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail @ £779.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.30GHz (3.90GHz TURBO)
- Multiplier: 33x (Unlocked Multiplier)
- L3 Cache: 15MB
- TDP: 130W
- 3yr Warranty
Was £849.95 Inc. VAT
Only £779.99 inc VAT.
ORDER NOW
AMD Llano A8-3870K 3.00GHz (Socket FM1) APU Processor (AD3870WNGXBOX) @ £105.59 inc VAT
Systems powered by AMD A-Series APUs with discrete-level graphics deliver up to 3X the visual performance of competing Intel Systems. Boost visual performance by at least 120% when you combine an AMD A-Series APU with select AMD Radeon™ HD 6000 Series graphics cards. AMD Turbo CORE Technology dynamically adjusts to users’ various workloads, delivering up to 300MHz of additional frequency on select AMD A-Series APUs. The APU Enables the graphics features and performance users demand with full DirectX®11 support.
Features:-
- Highly overclockable
- Socket FM1
- 4MB Cache
- 4 Cores
- 3000MHz CPU Clock
- 400 Radeon Cores
- 600MHz GPU Clock
- Max DDR3 2133MHz
- Dual Graphics Yes
- Warranty: 3yr
Was £109.99 Inc. VAT
Only £105.59 inc VAT.
ORDER NOW
AMD Llano A6-3670K 2.70GHz (Socket FM1) APU Processor (AD3670WNGXBOX) @ £83.99 inc VAT
Features:-
- Socket FM1
- 4MB Cache
- 4 Cores
- 2700MHz CPU Clock
- 400 Radeon Cores
- 600MHz GPU Clock
- Max DDR3 2133MHz
- Dual Graphics Yes
- Warranty: 3yr
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
AMD Llano A4-3300 2.50GHz (Socket FM1) APU Processor (AD3300OJGXBOX) @ £47.99 inc VAT
The AMD Fusion family of Accelerated Processing Units (APUs) is coming. Working in conjunction with the advanced x86 processor cores, an APUs multiple vector cores enable software developers to create innovative new applications that expand usage models and make PCs fast, easy to use, and more intuitive. The recent introduction of new tools for thread-level and data-parallel applications development simplifies the task of creating these applications. The development platforms and tools are scheduled to be widely available. The rest is up to entrepreneurial developers and PC manufacturers.
- Socket FM1
- 1MB Cache
- 2 Cores
- 2500MHz CPU Clock
- 240 Radeon Cores
- 443MHz GPU Clock
- Max DDR3 1600MHz
- Dual Graphics Yes
Was £49.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £191.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.60GHz Clock Speed
- 4.20GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.9375v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Only £191.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8120 Black Edition 3.10Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £155.99 inc VAT
- 3.10GHz Clock Speed
- 4.00GHz Turbo Clock Speed
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.975v - 1.4125v
- 32nm technology
- 3 Year Warranty
Was £157.99 Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £83.99 inc VAT
We call it the new AMD FX 4-Core Processor Black Edition and it's unlocked for your overclocking pleasure. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Quad Core Technology
- 3.80GHz Turbo Clock Speed
- AM3+ Socket
- 4MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 95W
- Voltage: 0.925v - 1.4125v
- 32nm technology
- 3 Year Warranty
Was £94.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/12GX) @ £53.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (4GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £56.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair Vengeance RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (CMZ8GX3M2A2133C11R) @ £95.99 inc VAT
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. As a bonus, the attractive low price of Vengeance memory will also leave lots of room in your system build budget. Now available in Racing Red
Vengeance memory is designed specifically for the latest CPUs. Vengeance modules run at 1.5V for maximum compatibility with all Intel® Core™ i3, i5 and i7 processors, as well as the 2nd generation Intel processor family. Vengeance DDR3 memory is available in single modules, and two or three module kits, making it easy for you to match the DIMM population requirements of your motherboard.
Most Vengeance DIMMs are built with two gigabit RAM ICs. These extra-dense memory chips allow you to have 8GB of memory using only two DIMMs, or to populate your triple channel system with up to an insanely large 24GB of system memory for extreme multitasking performance.
Features:-
- Each two module set is tested at 2133MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 11-11-11-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 11-11-11-27 values at 2133MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 2133MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £99.95 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £53.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1600MHz, 1.50V
- 100% tested at 1600MHz in Intel based motherboards
- Lifetime Warranty
Was £59.99 Inc. VAT
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) @ £53.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-10-9-27 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £59.99 Inc. VAT
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX8GX3M2A2000C9) @ £59.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Two matched 2GB modules for use in high performance Intel Core i7, i5, and i3 dual channel processors
- Outrageously fast 2000MHz performance using 4GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 8GB (2x4GB Module)
- Pin Voltage: 1.50-1.65V
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX4GX3M2B2000C9) @ £35.99 inc VAT
- Density: 4GB (2x2GB Module)
Was £39.95 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit @ £299.99 inc VAT
Team Xtreem LV DDR3 2600 Quad-Channel CL10 uses selected chips and passes 100% stringent testing. 2600 MHz speed rate with 20,800MB/sec transmission bandwidth and covered in the super slim aluminum heat sink, to lift the transmission speed and quality steadiness to another level.
It is the only one to meet the extremely high standards of the 1T Command rate in the market, and its efficiency is 10% better than any other Quad-Channel memory!
Team Xtreem LV DDR3 2600 Quad-Channel is designated to exceed enthusiast’s high expectations by bringing them the ultimate OC experience.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth 20,800 MB/Sec (PC3 20,800)
- CL-value: 10-12-12-31 1T
- Working voltage: 1.55-1.65V
- PCB: 8 layer PCB
Was £319.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) @ £131.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £35.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- Lifetime Warranty
Was £39.95 Inc. VAT
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £35.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Was £43.99 Inc. VAT
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £47.99 inc VAT
nonl2br
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.<br /><br />
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.<br /><br />
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
<br /><br />
Features:-<br />
- Black PCB<br />
- Black high performance CAMO ALU heatspreaders<br />
- Ultimate performance memory<br />
- Activity LED's (RED / GREEN)<br />
- Temperature Probe<br />
- Crucial MOD software compatible<br />
- Each two module set is tested at 1600MHz<br />
- Tactical heat spreader for performance<br />
- Packaged together immediately following system test<br />
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.<br />
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.<br />
- XMP 8-8-8-24 values at 1600MHz, 1.50V<br />
- 8192 Megabytes of DDR3 memory<br />
- Two matched 4GB modules<br />
- 100% tested at 1600MHz in Intel based motherboards<br />
- Supports Intel Extreme Memory Profiles (XMP)<br />
- Lifetime Warranty<br />
- Sandybridge compatible<br />
- Bulldozer compatible<br /><br />
<iframe width="640" height="360" src="
Was £59.99 Inc. VAT
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £47.99 inc VAT
nonl2br
<br /><br />
Features:-<br />
- Black PCB<br />
- Activity LED's (ORANGE & BLUE)<br />
Was £59.99 Inc. VAT
ORDER NOW
Crucial 4GB (1x4GB) DDR3 PC3-10600C9 1333MHz 204-Pin SODIMM Module (CT51264BC1339) @ £17.99 inc VAT
The incorporation of DDR3 memory now extends beyond desktop systems to laptops, offering increased frequencies at lower voltage requirements. Crucials’s PC3-10666 SODIMM kits support blazing speeds and bring frequencies to notebook systems that were previously unimaginable. Gamers, enthusiasts, and business professionals will benefit from the greater overall computing experience that these new high-density, high speed modules have to offer their next generation system. Crucial PC3-10666 SODIMM modules will feature 9-9-9-24 timings at low 1.5V to keep power consumption at minimum levels. Maximized productivity with the latest games, programs, and operating systems. Crucial's DDR3 SODIMMs are built to provide optimal compatibility using the highest quality components screened out using the most sophisticated testing available to deliver exceptional system performance.
- 1333MHz DDR3
- CL 9-9-9-24
- Unbuffered
- 1.5 Volts
- Lifetime Warranty
- 204 Pin DIMM
- Apple IMac Compatible (Please check http://support.apple.com/kb/HT1423)
Was £20.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 7950 3072MB PCI-Express Graphics Card @ £347.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was £353.99 Inc. VAT
Only £347.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 7950 OC 3072MB PCI-Express Graphics Card (11196-02-40G) @ £395.99 inc VAT
- Core Clock: 900MHz
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £399.95 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £214.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6970 IceQ Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £269.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 900MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1400MHz (5.6Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Memory Clock: 5600MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Only £269.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6970 2048MB Twin Frozr III GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
This special Twin Frozr III Edition utilises the same PCB from the flagship lightning cards and as such has both performance and silent modes. With the amazing Twin Frozr III cooler for near silent operation, cooler running and great overclocking potential. There is no better value 6970 on the market!
Features:-
- Same PCB / Components as Lightning Version
- Huge overclocking potential (1000MHz+ Core possible though not guaranteed)
- Near Silent Operation
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Texture Units: 96
- ROPS: 32
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £275.99 Inc. VAT
ORDER NOW
MSI ATI Radeon HD 6970 OC Lightning 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £275.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/AMDLightningStatic.jpg" alt="MSI Lightning" /><br>
<br>
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records! <br>
<br>
<Font size="5"><b>Key Features</b></font><br>
<br>
<img src="http://marketing-uk.msi.com/images/power4.png" width="210" align="left" alt="power4" /><b>Industry-leading Power4 Architecture for Overclocking Reliability</b><br>
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there. <br>
<br>
<img src="http://marketing-uk.msi.com/images/lightningsplit.png" width="210" align="right" alt="Cooling" />
<br>
<b>Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level</b><br>
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.<br>
<br>
<img src="http://marketing-uk.msi.com/images/afterburner.png" align="left" alt="afterburner" /><br>
<b>Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage</b><br>
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
<b>King of Extreme Overclocking</b><br>
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking<br>
<br>
<img src="http://marketing-uk.msi.com/images/mcii.png" align="right" alt="Military Class" /><b>Carefully Selected Materials</b><br>
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
<br>
<br>
<img src="http://marketing-uk.msi.com/images/MUSTHAVE.png" alt="Kit Guru Gold" /><img src="http://www.vortez.co.uk/contentteller.php?ct=content&action=file&id=21" width="200" alt="vORTEZ Gold" />
<br>
<br>
<Font size="5"><b>Specifications</b></font><br>
<br>
<b>Stream Processors</b> - 1536 Units<br>
<b>Core Clock</b> - 940 MHz<br>
<b>Memory Clock</b> - 5500 MHz<br>
<b>Memory Size</b> - 2048MB GDDR5<br>
<b>Memory Bus</b> - 256 bits<br>
<b>Output</b> - Mini DisplayPort*2 / HDMI / DVI*2<br>
<b>TDP</b> - 269 W<br>
<b>Card Dimension</b> - 310x127x40mm<br>
<b>Form Factor</b> - ATX<br>
<b>DirectX 11</b> - Y<br>
<b>OpenGL 4.0</b> - Y<br>
<b>CrossFireX</b> - Y<br>
<b>Eyefinity</b> - Y<br>
<b>AVIVO HD</b> - Y<br>
<b>PowerPlay</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
- World’s first 18 phase PWM on HD 6970.<br>
- Independent Memory Power support. <br>
- Copper MOS with 2x high current capacity. <br>
- Proadlizer*4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter. <br>
- Propeller Blade technology for 20% more airflow. <br>
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation. <br>
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- Support voltage adjustment of GPU/Memory/VDDCI<br>
- Military Class II Components for longer product lifespan. <br>
- LPL (Lightning Power Layer) for the stable power supply.<br>
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!<br>
<br>
<b>- Now with Three Year Warranty</b><br>
<img src="http://emm.msi.com/admin/temp/newsletters/1226/3yearfinal.jpg" width="250" alt="3 year warranty" /><br>
Was £299.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £209.99 inc VAT
The SAPPHIRE HD 6950 Dirt3 Special Edition is a new SAPPHIRE original model with a special cooler using a new dual fan configuration. Based on the latest high end AMD GPU architecture, it boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speed of 800MHz for the core and 2GB of the latest GDDR5 memory running at 1250Mhz (5 Gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS settings and performance can be further enhanced with the SAPPHIRE overclocking tool, TriXX, available as a free download from http://www.sapphiretech.com/ssc/TriXX/
Features:-
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 x Dual-Link DVI-I, 1 x Single-Link DVI-D, 1 x HDMI, 1 x DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- Warranty: 2 Years
Was £219.95 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card with FREE BattleField 3 PC Game @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tessellation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Memory Interface: 256-Bit
- Display Connectors: 1x Dual-Link DVI, 1x Single-Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- OpenGL 4.1 Support
- ATI Avivo HD
- Warranty: 2 Years
- BF3 Game
Was £269.99 Inc. VAT
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £124.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
The SAPPHIRE HD 6800 series features the second generation of graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
- Core Clock: 775MHz
- Memory Clock: 4000MHz (Effective)
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with DIRT3 Full PC Game download code (subject to availability)
Was £119.99 Inc. VAT
ORDER NOW
XFX ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card @ £125.99 inc VAT
- Memory Clock: 4200MHz (Effective)
- Processing Cores: 1120
- Display Connectors: 1 Dual Link DVI and 1 Single Link DVI, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £137.99 Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £101.99 Inc. VAT
ORDER NOW
Asus ATI Radeon HD 6770 1024MB GDDR5 PCI-Express Graphics Card @ £76.79 inc VAT
Now, more people than ever can experience real innovation in DirectX® 11 gaming with AMD Radeon™ HD 6770 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
Precision mounted DirectCU copper heatpipes in direct contact with the GPU for rapid heat dissipation – creating 20%* cooler and quiet performance in idle.
Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan.
Unique fan design dissipates heat efficiently while extending a graphic card’s lifespan by 25%* through increased dust and particle resistance. Intelligent system monitoring for efficient overclocking with an intuitive slide bar. Real-time overclocking, benchmarking and video capturing in any PC game!
Features:-
- DirectCU copper heat pipes directly contact with the GPU for rapid heat dissipation for 20%* cooler operation compared to reference
- Pump up graphics performance with Super Alloy Power that delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- DirectX 11® brings new levels of visual realism to gaming on the PC
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI 1.4a & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- 3yr Warranty
Was £84.95 Inc. VAT
Only £76.79 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6670 "Ultimate Edition"1024MB GDDR5 PCI-Express Graphics Card @ £71.99 inc VAT
The SAPPHIRE HD 6670 ULTIMATE Edition delivers new gaming experiences and acceleration of next generation high performance applications yet runs totally silently. All of this comes with low active power consumption and Dynamic Power Management delivering super low-power operation in 2D or idle. As the core technology is low power, no external power connection is required, making this series ideal for system upgrades or mainstream PCs that do not have high end power supplies.
Features:-
- SILENT DESIGN
- Processing Cores: 480
- HDCP Capable
- ATI Avivo HD
- Dimension 164(W) x40(W)x 107(H) mm Size.
- Warranty: 2 Years
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6670 2048MB GDDR3 PCI-Express Graphics Card @ £55.19 inc VAT
The AMD Radeon HD 6670 graphics processors offer advanced video and display features, as well as AMD's 2nd generation support for DirectXR 11 to give you the ultimate in "visual immersion" for your PC.
- D-Sub(VGA);
- Dual-Link DVI;
- HDMI 1.4a;
- 40nm Process Technology;
- Hyper Memory Support;
- AMD Avivo HD (DVD/HD-DVD/Blu-ray Playback);
- PCI-Express 2.0;
- AMD HD3D Technology;
- Microsoft DirectX 11;
- OpenGL 4.1;
- Shader Model 5.0;
- AMD Catalyst Control Center;
- Accelerated Video Transcoding;
- Dolby TrueHD and DTSHD Master Audio Support;
- Enhanced Unified Video Decoder 3 (UVD 3);
- Enhanced Internet Browser Applications;
- Windows 7 support;
- AMD App Acceleration;
- 2 Years Manufacturers Warranty;
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6570 HM 1024MB GDDR3 PCI-Express Graphics Card (11191-01-20G) @ £45.59 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6570 graphics processors offer advanced video and display features, HDMI 1.4a for stereoscopic (3D) displays, as well as 2nd generation support for DirectX 11 to offer the ultimate in versatility for the everyday computing desktop.
- Core Clock: 650MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1800MHz (Effective)
- HDCP Capable
- ATI Avivo HD
- Dimension 169(L) x 19(W)x94(H) mm Size.
- Warranty: 2 Years
Was £49.99 Inc. VAT
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card @ £21.59 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Memory: 512MB GDDR3
- Memory Interface: 64-Bit
- Memory Clock: 1066MHz (Effective)
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was £23.99 Inc. VAT
Only £21.59 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £347.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
- Supplied with FREE Mafia 2 PC Game Download Code (Subject to availability)
Was £359.99 Inc. VAT
ORDER NOW
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £455.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £469.99 Inc. VAT
ORDER NOW
OcUK GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £335.99 inc VAT
Features:-
- Core Clock: 772MHz (Fermi GF110)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £349.99 Inc. VAT
Only £335.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game @ £257.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/PowerEdition.jpg" alt="Power Edition" /><br>
<br>
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
<Font size="4"><b>Key Features</b><br></font>
<b>Propeller Blade on Twin Frozr III</b><br>
- Twin Frozr III Thermal Design with 18C cooler & 7.7 dB quieter.<br>
- Propeller Blade technology for 20% more airflow.<br>
- Dual 8cm fans with dual 8mm SuperPipes for best heat dissipation.<br>
<br>
<b>Power Edition Architecture</b><br>
- Triple overvoltage function support by MSI Afterburner to raise overclock capability.<br>
- 6+1 Phase PWM Design provides better overclock stability.<br>
<br>
<b>MSI Exclusive P/S Switch Function</b><br>
- Dual fan speed profiles–Performance/Silent.<br>
- Performance Mode provides best cooling demand; Silent Mode balances noise and GPU Temperature.<br>
<br>
<b>Military Class II Components</b><br>
- SFC (Super Ferrite Choke) has higher current for better overclocking ability.<br>
- Hi-C CAP for GPU provides more precise voltage.<br>
- All Solid CAPs have longer lifespan.<br>
<br>
<Font size="4"><b>Specification</b><br></font>
- Core Clock: 770MHz <br>
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)<br>
- Memory: 1280MB GDDR5<br>
- Memory Clock: 4000MHz (Effective)<br>
- Memory Interface: 320-Bit<br>
- Processing Cores: 480<br>
- Shader Clock: 1540MHz<br>
- Bus Type: PCI-Express 2.0<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready (Upto 3-Way SLI Supported)<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 4.0 Support<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
- 3D Vision Enabled<br>
- NVIDIA Surround Enabled<br>
- Warranty: 3 years<br>
ORDER NOW
Asus GeForce GTX 560 DirectCU 1024MB GDDR5 PCI-Express Graphics Card @ £137.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Processing Cores: 336
- Shader Clock: 1620MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £149.99 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card @ £165.59 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 830MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 830MHz
- Processing Cores: 384
- Shader Clock: 1660MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £169.99 Inc. VAT
Only £165.59 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/560tfiibannerawards.jpg" width="768" alt="Hawk" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>Twin Frozr II Thermal Design 20 Degrees Celsuis Cooler!!</b><br>
- Dual 8CM PWM Fans for 50% more air alow can cool down GPU/Memory/Power Module at once.<br>
- Four heat pipes with SuperPipe Technology<br>
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.<br>
<img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf01.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf02.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf03.jpg" align="centre" width="220" alt="Triple Over Voltage" /><br>
<br>
<b>7+1 Phase PWM Design</b><br>
- Higher current to GPU Powerv
- Higher overclocking capability<br>
- Better stability in peak load <br>
<br>
<b>Military Class Components</b><br>
- Hi-C Cap provides more precise GPU voltage.<br>
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.<br>
- All Solid CAP for longer lifespan. <br>
<br>
<img src="http://eu.msi.com/pic/feature/features_20091001175702.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s113_20080924184632.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s114_20080924184756.gif" align="left" alt="MSI" />
<img src="http://www.msi.com/pic/feature/features_20101116171850.jpg" align="left" alt="MSI" /><br>
<br>
<br>
<br>
<br>
<br>
<BR>
<BR>
<br>
<font size="4"><b>Specifications</b></font><br><br>
- Dual 8cm PWM Fans for 50% more airflow.<br>
- Superpipe technology and nickel-plated copper base for better dissipation<br>
- 20c cooler than reference design<br>
- Military Class II Components<br>
- Core Clock: 880MHz <br>
- Memory: 1024MB GDDR5<br>
- Memory Clock: 4200MHz (Effective)<br>
- Memory Interface: 256-Bit<br>
- Processing Cores: 384<br>
- Shader Clock: 1760MHz<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready <br>
- HDCP Capable<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
<br>
Only £173.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 560Ti 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
With 2X memory size, Palit GeForce® GTX 560 Ti 2GB support better performance at maximum resolution monitor while GPU works alongside the CPU to drive fantastic graphics performance. You can enjoy the extreme performance while playing the latest DX10/DX11 PC games under HD large screen with Palit GeForce® GTX 560 Ti 2GB.
Features:-
- Core Clock: 822MHz
- Shader Clock: 1645MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
- Upto 220% faster than 1GB version in BF3: http://forums.overclockers.co.uk/showthread.php?t=18344290
Was £215.99 Inc. VAT
ORDER NOW
OcUK GeForce GT 520 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £29.99 inc VAT
Make your video experience better. Whether you stream 1080p online videos from sites like YouTube® or Hulu® or prefer immersive Blu-Ray 3D™ movies, the power of the GeForce® GT 520 GPU makes your video playback fast and smooth.
In addition to rendering your high-res photos instantly, the GeForce® GT 520 also speeds up the editing of your videos. And when you share your photos and videos online, you'll enjoy a richer web experience with GPU accelerated browsers like Google Chrome™ and Internet Explorer® 9.
Go beyond photos and videos and take your gaming to the next level. With the GeForce® GT 520, your favourite DirectX11 games come to life with lifelike characters and incredibly detailed terrain and game environments.
Features:-
- Core clock: 810Mhz
- 1x HDMI
- 1x Analogue
- 1x Dual-Link DVI
- DirectX Version: 11
- OpenGL Version: 4
- SLI Support
- Warranty: 2 Years
Was £32.99 Inc. VAT
ORDER NOW
OcUK GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675MHz
- Memory Clock: 3600MHz (Effective)
- Shader Clock: 1350MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.3a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £99.95 Inc. VAT
ORDER NOW
Asus GeForce GT 440 SILENT 1024MB GDDR3 PCI-Express Graphics Card @ £53.99 inc VAT
NVIDIA® GeForce® GT 440 is the performance boost your PC needs to GPU accelerate the editing of your photos and HD videos, watch Blu-Ray 3D movies and play hot PC games on the latest DirectX 11 titles like Civilization V. Equipped with the latest industry leading technologies including NVIDIA® PhysX®, NVIDIA® CUDA™, high performance NVIDIA GeForce drivers, and more, GeForce GT 440 has everything you need to accelerate your digital life.
The flattened copper heat-pipe contacts GPU directly for 0dB cooling experience.
Specification:-
- Effective and quiet DirectCU Silent 0dB thermal design
- SILENT DESIGN
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £56.99 Inc. VAT
ORDER NOW
Gigabyte GeForce GT 430 OC "Dual Fan" 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £47.99 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 730MHz
- Shader Clock: 1460MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Warranty: 2 Years
Was £53.99 Inc. VAT
ORDER NOW
OcUK GeForce GT 430 1024MB GDDR3 PCI-Express Graphics Card @ £35.99 inc VAT
Specification:-
- Core Clock: 700MHz
- Memory Clock: 1600MHz (Effective)
- Shader Clock: 1400MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £43.99 Inc. VAT
ORDER NOW
MSI GeForce N210 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £21.59 inc VAT
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them to Facebook up to 50% faster with the GeForce 210. Convert your video and put it on your iPod in minutes instead of hours or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-Ray Movies? It doesn’t matter, the GeForce 210 can playback any Blu Ray Movie with any modern CPU.
- Core Clock: 589MHz
- Memory Clock: 1000MHz (Effective)
- Processing Cores: 16
- Shader Clock: 1178MHz
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 2 Years
Was £23.99 Inc. VAT
ORDER NOW
BenQ G925HDA 18.5" Widescreen LCD Monitor - Black @ £65.99 inc VAT
The BenQ G925HDA is built to broaden your view with 18.5“W 16:9 LCD display! The best part is it’s also energy efficient, reducing power consumption by 23.3% in comparing to previous model.
5ms response time means that even highly dynamic video is rendered fluidly without ghosting or other artifacts.
With a dynamic contrast ratio of 40000:1 to give you splendid image details and clarity in darkened and complex motion pictures, everything becomes more vivid!
BenQ’s exclusive Senseye®+Photo Technology gives you preset modes—Standard, Dynamic, Movie, Photo—that provide instant optimized settings for different usage scenarios. Senseye®+Photo is an enhanced version that adds support for the industry-standard sRGB color space, allowing you to obtain consistent results when you view and manipulate images on the G925HDA and on other sRGB-compliant devices.
This mode allows aspect ratio’s other 16:9 to be displayed without geometric distortion. So, it can perfectly display a full picture with its 16:9 widescreen panel – allowing you to enjoy the best visual entertainment.
Features
- Screen Size: 18.5" Wide
- Resolution (max.): 1366 x 768
- Pixel Pitch: 0.3 mm
- Brightness: 200 cd/m²
- Contrast Ratio: 700:1
- Dynamic Contrast Ratio: 40,000:1
- Response Time: (tr/tf) 5ms
- Display Area: 409.8 x 230.4 mm
- Display Color: 16.7 million
- Viewing Angle: (L/R;U/D) (CR>=10) 90 / 65
- Terminals: D-sub
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 110
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 23W (on mode)
- Auto Switching Power Supply Built-in
- Power Saving Mode <1W
- Senseye+Photo Technology
- HDCP Support: NO
- Adjustments Tilt: -5 / 20 (down / up)
- Dimensions (HxWxD): 345.8 x 444.4 x 165 mm
- with wall mount: 278.8 x 444.4 x 62.1 mm
- Weight: Net 2.8 kg / Gross 4.3 kg
- Accessories (Standard): VGA cable / Power cable
- Warranty: 2yrs
Was £73.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Iiyama ProLite P1705S-B 17" Hard Glass LCD Monitor - Black @ £95.99 inc VAT
The ProLite P1705S meets the increasing demands for Protected LCD’s within Education, Retail and Industrial applications. In addition to having toughened safety glass fitted behind the bezel at 8H hardness rating capable of resisting above normal impacts to the display, iiyama have enhanced the range to include the latest high performance and energy saving technology. Features include 5msec response time, 1000:1 contrast ratio enhancing colour and Analogue and DVI inputs. The displays are Energy Star rated and have 19W typical power consumption in use and less than 1W in standby.
All iiyama monitors are compatible with Apple-Macintosh computers.
Main Features:
- Iiyama ProLite P1705S-1 Monitor
- 17 inch (43cm) TFT LCD Screen Size
- Glass hardness: 8H minimum
- Native resolution: 1280 x 1024 (SXGA)
- Contrast ratio 1000 : 1 typical
- Brightness 250 cd / m2 typical
- Response time: 5 msec
- Input connector: DVI-D, D-Sub
- 2 x 1W Speakers
- Kensington-lock prepared
- Colour: Black
Was £104.99 Inc. VAT
ORDER NOW
Dell IN2020N 20" Widescreen LCD Monitor - Black @ £79.99 inc VAT
Enhance your multimedia experience with the IN2020 high-definition monitor with LED. This 20" widescreen display offers brilliantly vivid features at an even more brilliant price.
Highlights of the Dell 20" Wide IN2020N 5ms LED HD
* Enhance your multimedia view
* Environmental footprint
* Convenient comfort
* Great-value performance
Expand your productivity and multimedia performance with this 20" widescreen display, including LED backlight. With its 16:9 aspect ratio, 8,000,000:1 high dynamic contrast ratio and 1600 x 900 high-definition display, the IN2020 is excellent for viewing movies, photos and videos. Plus, you'll never skip a beat by adding the optional multimedia Dell soundbar for an enhanced audio experience.
The IN2020 monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, Energy Star 5.0, to help you lower energy consumption without sacrificing performance.
Convenient comfort
The IN2020 monitor is uniquely designed for comfort, convenience and visual appeal. With tilt adjustability, the IN2020 offers a versatile and comfortable view. The high-gloss slim black bezel complements both your home environment and your Dell desktop or laptop. Simply connect to any standard computer using the VGA connector.
The IN2020 monitor delivers a high dynamic contrast ratio of 8,000,000:1, vivid 1600 x 900 high-definition resolution, a fast response time and VGA connectivity, all at an affordable price.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 1000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 160°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- Dimensions: 453.7mm x 344.0mm x 204.8mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was £85.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Iiyama ProLite E2008HDS 20" Widescreen LCD Monitor - Black @ £89.99 inc VAT
The Iiyama E2008HDS-1 20" LCD offers great value for money, and is the ideal screen for Gaming or as a Home Office display. Iiyama’s Opti-Colour Modes ensure high colour performance, supported by an ultra fast 2ms response time and a high 1600x900 resolution. With DVI and VGA connections and Iiyama’s new Power Saving Eco Modes, you are in safe hands with this superb display.
- Contrast Ratio: 30000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 485.0mm x 367.0mm x 193.0mm
- VESA Compliant
- Weight: 4.0kg
- Stereo Speakers
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
NVIDIA 3D Vision Kit with Duke Nukem Forever @ £79.99 inc VAT
Upgrade your PC to a fully immersive stereoscopic 3D experience with Nvidia GeForce 3D Vision. A combination of high-tech wireless glasses and advanced software, GeForce 3D Vision automatically transforms hundreds of PC games into full stereoscopic 3D. Just slip on the stylish glasses and pair them with an Nvidia GeForce GPU and a "GeForce 3D Vision-Ready" display to experience characters and environments come to life on the screen. In addition, you can watch 3D movies and 3D digital photographs in eye popping, crystal-clear quality. Give your eyes something to talk about with GeForce 3D Vision. Requires 120Hz Monitor.
- Convert standard games into stereoscopic 3D
- Highest quality stereoscopic 3D solution
- Designed for comfort and style
- Wear over your prescription glasses
- High power wireless infrared communication
- Game for more than forty hours on a single charge
- Adjust 3D depth adjustment from the IR emitter
- Watch movies in 3D
- Stereoscopic 3D picture support
- Supplied with Duke Nukem Forever Full Game Download
NOTE: Requires 120Hz Monitor
NOTE: Requires Nvidia GeForce 8800 GTX or above Graphics Card
Was £113.99 Inc. VAT
ORDER NOW
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black @ £99.98 inc VAT
The ProLite E2208HDD Widescreen LCD features true High Definition, 16:9, 1920 x 1080 pixels as its native resolution. Impressive colour reproduction is achieved with a typical contrast ratio of 1000:1 with the User Option to enhance further with Advanced Contrast Ratio enabled for 10000:1. 'Opticolour' automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 170°/160°
- VESA Compliant
- Dimensions: 516.5mm x 386.0mm x 193.0mm
- Weight: 4.2kg
Only £99.98 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Contrast Ratio: 5000000:1
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
Was £134.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
OcUK E2250SWDA 22" Widescreen LED Monitor - Black @ £79.99 inc VAT
The OcUK 22" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 20,000,000:1 contrast ratio and digital connectivity there is no other LED that can match the combination of value and performance.
Features
- Screen Size: 21.6" Widescreen
- Contrast Ratio: 20,000,000:1
- Multimedia Speakers
Was £89.99 Inc. VAT
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £179.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was £199.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black @ £149.99 inc VAT
ProLite X2377HDS - A 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all around panel type. This IPS panel offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2377HDS is full HD, has a 5 000,000:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user clear and vivid images. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The Prolite X2377HDS has two integrated stereo speakers and is VESA mount compatible. It will provide both excellent performance for photographic, design and web-design and is also an excellent choice for Universities, Corporate and Financial Markets, as well as the rapidly expanding demand for Multi Monitor applications.
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- Multimedia Stereo Speakers
- 3yr Warranty
Was £155.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £339.98 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was £379.99 Inc. VAT
Only £339.98 inc VAT.
ORDER NOW
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Contrast Ratio: 60000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
Only £143.99 inc VAT.
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £131.99 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Only £131.99 inc VAT.
ORDER NOW
IIyama Prolite E2473HDS 24" Widescreen LED Monitor - Black @ £149.99 inc VAT
The ProLite E2473HDS LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr On-site Warranty
Was £161.99 Inc. VAT
ORDER NOW
OcUK 2436VWA 24" Widescreen LCD Monitor - Black @ £119.99 inc VAT
The OcUK 24" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 60,000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
Features
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 60,000:1
- Colors: 16.7 M
- HDCP compatible: Yes
- USB: 1up / 1down
- VESA 100x100mm
Was £131.99 Inc. VAT
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £179.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- VESA Compliant
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £479.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- True Resolution : 1920x1080
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Earphone jack : 3.5mm Mini-Jack
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was £539.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Hazro HZ30Wie 10-Bit 30" LCD Widescreen Professional Monitor - Black @ £699.98 inc VAT
The Hazro HZ30Wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30Wi performs with consistency and clarity to optimise your visual experience. The Hazro HZ30Wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30Wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30Wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30Wi offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30Wi is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 3yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Was £719.99 Inc. VAT
Only £699.98 inc VAT.
ORDER NOW
Iiyama ProLite E2773HDS 27" Widescreen LED 1MS Monitor - Black @ £239.99 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
Features:
- LED Backlit
- Full HD
- ACR Capeablity
- Inbuilt Speakers
- HDMI Input
- Overdrive Feature
- VESA Mountable
- Compatible with Xbox 360 & PS3
Technical Specifications:
- Contrast Ratio: 5 000 000 : 1
- Response Time: 1ms
- VESA Compliant
- Adjustable Stand
- Weight: 5.3kg
Was £259.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
