Do you mean disable all fan speed control for the whole system?
Could I not plug the pump cable into 'CPU_FAN OPT' which according to my manual is not supported by 'ASUS FAN Xpert feature'? As I'm not to keen on the idea on having 6 fans all spinning at full rpm?
You know theres a water cooling forum?
They aren't watercooling!![]()
Get back in your hole.
What has a silent mode?
Would my ram not get in the way?
Id personally plug the pump into the PWR fan header, this fan header will run the pump at its full speed. The PWR fan header on asus boards doesnt feature speed control. Then plug the fan into the cpu fan header. This way you can keep fan control enabled.
I wouldnt do it, your RAM is too tall for most things.
