- 5 Feb 2012
Okay, thank you.
In just under an hour (50 minutes) I have clocked up 18 CRC errors and 16 errored seconds. Is that considered okay taking into account the 40dB attentuation?
Sounds OK what are the following values?
Yep thats ok, we are at a busy (noise wise) point of the day so fine. Mine pushes more than that and seems fine (although mine dips to 3dB during the night).
What are your stats?
Reed Solomon: 15638754
RS Corrected: 615690
RS Un-Corrected: 221
Since mid Jan i have been able to get on TalkTalk LLU (first LLU in the exchange and only option to BT IPStream products) and i now havent seen any noise spikes and i've been synced for 11 days solid. The only thing thats changed is the kit at the exchange i'm connected to, must be the old crappy BT kit!!!
Corrected are 3.9% which is fairly high - you might see the line retrain slightly lower
