The XMS3, and most other 1600MHz DDR3, should run fine at ~1.5V so why not if it can?
Just doing what I've been told to do, basically set the settings to whats on the RAM and it will be fine.
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
That's your choice but it's not a reason for the OP not to use a lower voltage if they can and follow what OcUK and Intel tell him to do:
VDDQ: more commonly known as Vdimm or Vdram, this is the voltage for your memory. Formally known as I/O voltage for DDR3, Intel states maximum at 1.575. YOU should run this at whatever it says on your RAM. At the time I am writing this article, 1.575 is not the standard, but 1.5v has been stock voltage on many DDR3 RAM modules for a long time. While at 1.5v you can run at stock speed of 1333 MHz and SPD 9, 9,9,24 to run your RAM at a higher speed, such as 1600MHz, most RAM requires 1.65v. Do not be afraid, if it says 1.65v on your RAM stick, set it to 1.64 or 1.66v. For overclocking higher than what your RAM is rated for you can take this up, I have used up to 1.76v, but for my tests I used 1.72v to run my 1600mhz Ram at 1866mhz. I wouldn’t run this voltage over 1.8v unless you are going for some crazy high clocks.
So I think im safe thanks![]()
They may know more about the RAM than people who make the CPU's?![]()
Also to much Vcore for too long is the main killer of these chips.
You're just being stubbornly blind to the issue if you can't agree that it's better to use ~1.5v, if you can, rather than 1.65V.
