AMD HD7770 PR Stunt ?
Where does it say the 7770 is going to be weaker than the 6870, and where does it say the price? :confused:
It goes without saying they're going to be weaker. Less stream processors, narrower memory bandwidth. About the only thing they've got going for them is their 1GHz core clock. If you do a bit of googling it all becomes clear ;)
They'll probably be getting near stock 6850 performance with prices around about £100-£110
This ^.
Price is a stipulation, from history you'd expect around 110-120 quid for the 7770, 6870's at times can be had for 125ish now.
7770 Looks to be around 6850 performance, which is a sub 100 quid card now.
So if that leak is from December, then what the hell are they waiting for, release it already, must be ready.
I'm going to wait for kelper and buy a new GPU or snap up an old one at a reduced price.
The leaks put the card at around HD6850 level performance but with 2GB of GDDR5 RAM! I assume it will have improved tessellation ability over the HD6800 series, although the leaked pictures shows it still has a PCI-E power connector. I don't see the point of 2GB of GDDR5 RAM for this card,and TBH it should have been bus powered.
7700 specifications?
http://www.techpowerup.com/160270/Radeon-HD-7700-Series-Specifications-Surface.html
Cape Verde Physical
Built on TSMC 28 nm process, ~1.5 billion transistors
10 Graphics CoreNext Compute Units (CUs)
640 stream processors
40 TMUs, 16 ROPs
128-bit wide GDDR5 memory interface
Radeon HD 7770
All CUs enabled, 640 stream processors
1 GB GDDR5 memory
40 TMUs, 16 ROPs
1000 MHz core clock-speed
1125 MHz (actual), 4500 MHz (effective) memory clock-speed
72 GB/s memory bandwidth
1280 GFLOP/s single-precision floating-point performance
Typical board power: 80W
Radeon HD 7750
8 CUs enabled, 512 stream processors
1 GB GDDR5 memory
32 TMUs, 16 ROPs
800 MHz core clock-speed
819 GFLOP/s single-precision floating-point performance
Typical board power: 55W
So the 7750 should be bus powered yeah? 75W for a PCI-E slot isnt it? so the 7770 will need a single 6pin extra as its just over.
Will someone make a"Green edition" that is underclocked a bit to do away with the 6pin connector.
