I have been told by some serious peeps that just giving the RAM what they require at the speed and timings to suit is absolutely fine![]()
And the vast majority of the 1600MHz RAM sold by OcUK only requires ~1.5V
Product Description
8GB XMS Memory kit for dual channel systems, 1600MHz, 9-9-9-24, 1.65V
Key Features
Maximize your system memory capacity for ultimate performance
Guaranteed to work on all dual channel Intel and AMD platforms
XMS heat spreader
World famous Corsair reliability and performance
Package Contents
Two 4GB memory modules
System Requirements
Designed for use with all DDR3 motherboards with two memory channels
And the vast majority of the 1600MHz RAM sold by OcUK only requires ~1.5V![]()
Product Description
Key Features
XMS heat spreader
Package Contents
System Requirements
Sure? Im seeing a lot of 1.5-1.65v sets![]()
A quick count of the RAM at OCUK shows that 16 of the 32 1600MHz kits are 1.5v-1.65v
I'm sure the manufacturers of the RAM know what they are doing.
I give my CPU as much voltage as it needs to remain stable and to keep temperatures within check, this isnt related to RAM timings etc and so I always trust the RAM manufacturer first and other long time OC experts.
CPU still going fine thanks and is solid as a rock.
Memory Voltage: As with LGA1366 and LGA1156 CPUs, keep this value to within 0.5V of the VCCIO voltage to prevent long term damage to the CPU. By default, this is 1.1V, which means the 1.65V used by previous Intel DDR3 memory is still acceptable. However, more recent memory will be rated at 1.5V (or even 1.35V if you choose a low-voltage kit). Increasing the VCCIO voltage obviously gives you more overhead on your memory voltage (remember, add +0.5V at most or risk damaging your CPU).
with the same wink-and-a-nod from engineers that up to 1.65 V is safe
Memory - Intel recommend 1.50v plus/minus 5% which means 1.60v is the ideal safe maximum, but we have found in our testing all 1.65v memory is fine. We have also found most new 1.65v like Corsair XMS3 will run at its rated timings with just 1.50-1.55v which is well within Intel specifications. So people upgrading to Sandybridge you can still use your old DDR3, but we do recommend you run it at 1.60v or less. We are shipping most of our bundles which feature Corsair XMS at 1.50v-1.55v at rated timings. We've also discussed with Asus and MSI regarding voltages for memory and they also confirm in their testing 1.65v caused no issues with reliability.
I assume you'll be advising OcUK that that their guidance is wrong?
Your scaremongering won't change this.
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
DRAM voltage – This is directly related to your RAM modules and increases will allow increase in MEM speeds. There has been a lot of debate as to the limitation 1.65V limitation Intel has published. With the older platforms, the rules no longer apply. With a few months past now, it seems safe to say that this platform is robust enought to handle running memory at higher voltages, at least for the short term. Many overclockers still want to push the limits, but since all the current memory seems to scale less with voltage than older stuff, this is becoming a moot point. I’d still suggest staying at 1.65V or below for a regular daily system,[/B[ but I’ve pushed up to 1.85V for short benching sessions without any adverse effects.
My Modules are rated for 1.8v, can I use them? - 1.8v modules are not suitable for use in P67 boards unless you run them at 1.65v or less - Keep in mind that as you are under-volting the modules, they will probably not run at their rated speeds, so doing this isn't recommended unless you know what you are doing.
You can reply back if you want, but the facts remain that there are a huge amount of Sandybridge OC guides and forum threads from multiple forums (just simply Google "Safe RAM voltage for Sandybridge" or similar) that all say different to you.
And I will quote the Sandybridge OC guides again.
