Prior to using it, i was running the afterburner fps limiter, (59 fps set). Without the limiter i was averaging 93 fps, now about 88 with the fxaai. Seems that it disables the afterburner frame limiter. Also lost msi on screen display, though it still works on my g15 lcd.does the fxaa injector reduce fps much?
I never used digital vibrance tbh prior to this. My monitor has a dynamic preset for games, though it left the colours too bright. But then the benq fp241w was always notorious for being too bright on any preset.Thanks Setter, doesn't look any different than Digital Vibrance![]()
Evening all,
I'm an admin on the SaS server. A chap called 'crinkleshoes' was playing with an OCUK clan tag, and seemed, well... rather good. A large number of kills at long range with a pistol and a k/d of 44-4. I searched for his screen name on here and he seems to have made a large number of posts - any thoughts? He has not been banned... only temporarily removed. If he's legit, then fair play to him!
Feel free to have a search for my soldier, same nickname - i've had good matches interspersed with bad...
(hate the dark, gritty colours especially on the Wake Island map, everything is sooooo dark and gloomy), may have to start playing this again, once it (if) gets patched, can't wait for the MAV fix
Yes, it was me you kicked.
I've had a couple of really good killstreaks the last 2 days... I'm playing as sniper now the most + discovered the AN94 for assault & on conquest... I go for a cap and have just seemed to get lucky with such a ridiculous amount of bunching / people lining up in front of me while i'm looking down the sights. With sniper rifle, i usually switch to pistol before reaching the point - that's why i've been getting quite a few kills with it, seems to only need 1-2 shots in HC. Add to that, I'm running on low settings while I level up and I'm starting to spray when I come round corners... is probably why i get a rather high TK ratio (oopsie).
Here you go.
SNIP
Stuff...
85, was using 70 before.what fov are you guys using? im seeing a lot more gun in your screenies than mine!
