Haswell to Launch March - June 2013 but No Ivybridge-E Before 2nd half of 2013
so i guess this is the decider for me then, so when i build my new pc in the next month or so, if i choose sandy E 2011im going to be able to upgrade to the next gen, so has intel stopped all this multiple socket malarke they did every 12 months then ? im conufused. i thought if i went sandy e in march, they would bring out a new socket by december
Ivy-E is the same socket as Sandy-E so far, so it will be a straight cpu swapout for a nice 22nm upgrade
so if i buy socket 2011 in march and ivy e isnt until say 2013 then id get a fulljust under 2 years ?
It all depends if intel release another good value 2011 chip like the 3820. If they do 2011 is a sound investment in my opinion.
am i right in thinking the 3820 will be very similar in performance to the 2700k but the only gain is the extra pci lanes and quad memory ?
Ok so a couple have people have suggested Ivybridge-E might be dropped moving straight to Haswell-E.
I can't ever remember Intel planning a chip then later scrapping it, I could be wrong though.
What does everyone else think about this & is there any info floating around to suggest that this might be the case?
How long after Sandybridge was Sandybridge-E launched?
The original Nehalem (next Netburst architecture) was binned. With such a large gap between SB and SB-E if there was something similar with IB then IB-E would have such a short lifespan as Haswell should hopefully be a fairly large performance increase over IB.
From what I've read it sounds like the performance gains are once again mainly going to be integrated GPU related as opposed to raw computational power although its being suggested overclocking will be 'easier' than Ivybridge.
'Easier' seems like a pretty vague term to use in this respect.
Those slides I posted also seem to suggest that Haswell will be a performance level below SB-E. If that's true there's no reason why Ivybridge-E should have a short life, perhaps they're won't be a Haswell-E until at least a year after vanilla Haswell like SB & SB-E & is scheduled between IB & IB-E.
I guess its anyone's guess really and we should just be grateful & enjoy the latest hot technology that's available what ever its called.
The slides show that they are aimed at different market segments.
Haswell (and probably vanilla Ivy Bridge) will be faster than SB-E for applications which only utilise 4 or less cores (i.e. what the majority of forum users will use them for).
Socket 2011 will be faster for heavily threaded applications which also require large amounts of memory bandwidth.
yeah it's kinda like how the current sandybridge cpus (2500k,2600k, etc) are faster not only clock for clock but also in applications utilising 4 cores or less, compared with last gen westmere (980x,990x). However in heavily threaded applications ( more than 4-5 threads), westmere comes on top.
are they already producing haswell chips or is that a sample? :)
Pre-production engineering sample.
Pretty much this exactly.
They dropped netburst chips like a bad habit and tbey recently dropped their video card chip because it was rubbish and couldn't keep up with even mid range amd and nvidia cards and thats before we even get onto the issue of driver updates which intel has no record of.
