Help me to decide please!
18 Dec 2008
Liverpool
Okay I know I have had a fair few spec me requests latley, not to mention many others....
Some of you may have read my spec request of between £3,000.00 & £3,500.00, I've now dropped this to £2,500.00 as I need to buy a decent laptop aswell.
However I have decided on the following so far:
At a total of £925.96; leaving me with a budget of £1,574.04
For the case I'm torn between the:
Leaving me with a budget of between £1,328.59 & £1,234.96 respectivley...
From the remaining budget I need everything not mentioned above including an operating system; I intend to dual boot with Linux.
The system will be used for gaming, photo editing some video editing, course work, some programming, internet browsing and everything else I may come across during a comp science degree, hopefully started by next September?
So what would you good people recommend? I'm open to any and all suggestions...
im not dissing the spec, just saying if the OP was to spend that much money, he/she might aswell get a blu ray drive.
and a bulldozer rig is still better than an athlon ii x2 laptop :(
Like Manuel from Faulty Towers, I know nothing! But to me the Coolmaster looks like an Honda generator :o
Fair point, I take it back I'm currently using a naff laptop aswell
Any reason why you need such big cases?
Also the Silverstone is out of stock.
Looks & functionality; I'm quite fussy when it comes to how cases look; I can't stand how the "Dark Fleet" type cases look, I had an Antec 902 for my last rig and it grated on me after a few weeks!
I wont be purchasing untill the end of March
YOUR BASKET
1 x Silverstone Fortress 2 FT02B-W Windowed Gaming Case - Black £209.99
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £167.99
1 x Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £144.98
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £139.99
1 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £99.98
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £96.98
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.98
1 x Samsung SH-B123L/RSBP 12x BluRay ROM / DVDRW DL & RAM Lightscribe SATA-II Optical Drive - Black (Retail) £59.99
1 x BeQuiet Dark Rock Advanced CPU Cooler (Socket LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940) £41.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £39.98
Total : £1,099.56 (includes shipping : £14.75).
I also like the Z68XP-UD4 motherboard.
As for the GPU, Kepler looks promising. Else, a 7950. I would sit tight, at least until kepler is launched. AMD has some room to lower its pricing. You can still buy the rest of the kit in the meantime and use the IGP.
I am not sure you should be spending so much on the case though. You could half the case budget and get something equally good. But yeah, I like the FT02-W myself :) But I wouldn't begrudge a Corsair 650D.
Can also consider a i7, if you are using some thread heavy software (video transcoding, 3D rendering).
Oh well, come back in march :) You'll have a better view of the GPU war that's about to start.
As for a laptop, ... I am using a UL30A. It's a 13'' notebook, and really a good complement to a desktop. Big battery life, can carry it anywhere, I would get a £350 AMD-E350 fusion laptop (or a i3) with a SSD. I don't rate big laptops at all.
Better off waiting a bit for specs with new CPUs and GPUs due for release around that time.
