Upgrade to run Adobe apps fast
11 Jun 2008
Barnoldswick
I have an Antec 1200 case with an Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB), Asus P5Q Intel P45 (Socket 775) PCI-Express DDR2 Motherboard, and a HIS ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI PCI-Express. I am considering upping this part of the rig to make Photoshop CS4 and Indesign CS4 run faster. Is this something that I should consider:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-000-GI&groupid=43&catid=2053&subcat=
Cheers guys.
I'd go for one of the Sandybridge bundles or make my own, unless you have a specific reason for that Nehalem Mobo. Photoshop CS4 and Indesign CS4 only use 1 core so SB would be fastest option.
For less money you can grab a better set of components:
YOUR BASKET
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail £239.99
1 x Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard £99.98
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £35.99
1 x Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £23.99
Total : £411.35 (includes shipping : £9.50).
i7-2600k is faster core for core than the i7-950: comparison
and you'll have more 2GB RAM to play with.
Or option 2:
Drop down to a processor without hyperthreading and include an SSD for quicker read/write speeds which will help when importing/editing images.
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £167.99
1 x ADATA S510 120GB SATA 6Gb/s Solid State Drive - Retail with Acronis True Image £115.99
Total : £455.34 (includes shipping : £9.50).
Thanks for the suggestions. With a very stable rig bought from OC, I have for a while not paid as much aatention as I would normally have done on newer technologies. Will look into Sandybridge options.
Would upgrading these components require a complete new install? Or would the new parts pick up the apps from the Seagate drives already installed?
Complete new install is almost certainly required.
Even if on the off chance it did load on your old install there would probably be lots of issues.
Had you been using CS5 I probably would have suggested an Nvidia GPU as a cheap upgrade to enable cuda support. I don't believe CS4 uses cuda although it maybe worth double checking.
Robbies suggestions are very good but you might not be aware that Ivybridge is on the horizon. The mobo he used i'm sure would take these ivybridge CPUs. So it depends if you can't wait or can make do for a lil while longer.
An SSD will greatly reduce read times for the OS and software installed to it. Even if that was all you bought now, your system would see a noticeable performance boost.
P.S
A fresh install is most wise for a mobo bundle upgrade. I should add that you could spread the cost by using robbies i5 build minus the SSD. That mobo can have a SSD attached later and be used as a "cache drive". This is a plugin upgrade, no reinstall of the OS would be necessary.
http://www.anandtech.com/show/4329/...mart-response-technology-ssd-caching-review/2
Thanks for pointing out the impending arrival of Ivybridge CPU's. Seems like I should hang on a bit longer - things aren't desperate at all.
