at 1080p almost impossible. your card is only twice more powerful than what's inside an xbox360 and we know it can barely handle skyrim at 720p with low-medium settings.
It handles Skyrim extremely well and its more like High settings it runs at. No love for consoles here lol
its 720p, 20-30 fps and low-medium settings if that is extremely well for you i dont know what else to say.
Lol it is 720p...check
But its not at all 20-30fps its smooth and having looked at Skyrim on both systems I'd definately argue about the medium settings. There are effects the 360 runs that arent used in medium on the PC
The PS3 struggles with Skyrim so Im not sure if your getting mixed up and consoles are much better optimised than you think it would seem lol
Conveniently forgetting all the background stuff when running it on PC which is going to rip into the specs...
Not a chance its going to run at 1080. I've got better specs that that (q6600 and 9600 gso even if they are both old and crap) and 1080 has terrible slow-down in places even with low settings and max view distance on items/objects/actors. 720 it runs a lot better though still occasionally suffers from low fps.
No it's not.
My friend runs Skyrim fine on 1680x1050 on a 5770.
What's holding you back is VRAM, so you can't use higher textures etc.
I'm loving the comments like
OP could run medium settings at 1920x1080 quite probably.
what flame war we havent called each other names just discussing.Lol its definately turning into a flame war haha
I'd say though the CPU is a limiting factor as Skyrim is CPU dependant. It'll never hit decent looks at 1080p thats for certain![]()
yes it is and the 5770 is much more powerful so i dont know why you even mention it.
4670 is 3 times more powerful than Xenos.
4850 is more powerful than the 4670.
The 5770 < 4870.
5770 is between the 4850 and 4870.
Clock the 4850 a little for a few extra frames.
Xenos = 64 shaders, the 4850 = 800 shaders, that's over 10 times the amount of shaders.
The 5770 < 4870.
PC gamers... Lol..
