Check before I buy please
8 May 2011
London
I'm planning on doing a loop, I already have the water blocks and a fan controller, and any required tools are provided by Cleeecooo (he's the one actually putting it together xD)
Here's my basket
YOUR BASKET
1 x EK CoolStream RAD XTX (360) £74.99
1 x OcUK Tech Lab - 10w DDC Pump & Alphacool Acetal Top Value Combo £62.99
1 x Phobya 5,25" Dual Bay Reservoir Black £32.99
1 x Mayhems Aurora - Tharsis Red Coolant 1L £14.99
4 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £12.98 (£51.92)
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
15 x EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black £3.50 (£52.50)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
Total : £314.63 (includes shipping : £10.00).
N.B Out of stock items I already have, and the pump is actually Cleeecooo's old D5+Top, I just put that one in for a similar price. The extra fan also goes at the back of my case.
So, any problems?
£1.30 for a paperclip? :p
IF you've got a fan controller I'd recommend getting 1800rpm scythe GT's instead (just in case the extra cooling power is needed)
Why have you got 15 fittings
For use on waterblocks etc. as I'm replacing all the tubing, and one spare fitting in case I lose one
Aurora is not really an everyday coolant, it's meant more for shows etc. You'd do better to switch it for Pastel or X1 IMO
Fair enough, but I'm still wondering about thatt
Fine apart from the amount of fittings as said previously, you could change the res to a tube one if you wish.
I prefer a bay res really
You still only need 9 fittings if you want one spare.
My advice wound be get some 2000rpm yateloons and a fan controller
will probably be a little cheaper plus you have more cooling power on tap if you need it.
The loop's got 2 gfx cards as well and it's 3 spare I wanted xD
Will 150 rpm (over the 1850 version of the gentle typhoon) make much of a difference?
ah right.
The speed difference will make at a guess 2-3 c but the noise will be more.
Unless you can control them
what cards you cooling.
