RAM Gigabyte GA-X38-DS4 Intel X38
9 Aug 2010
Hello,
I currently have 4gb ram and I was wondering whats the most amount of ram can i get with this board?
I have OCZ SLI-Ready Edition 4GB 1066MHz Dual Channel and wanted to upgrade for bf3
That's 2x2GB I assume?
You could buy 2x2GB of 800MHz RAM and run all 8GB at 800MHz.
Or you can ask OcUK when/if they'll be getting the 1066MHz RAM back in stock.
Or you can look elsewhere and perhaps consider second hand.
Unfortunately DDR2 is very expensive at £50/£60 for 4GB.
Edit:
You do have a 64 bit operating system so you can use more than 4GB?
