Hi guys,
I've just put this together:
This is all in a Silverstone Raven RV01 case.
That is all that has been in the PC. I used an external DVD drive to install Windows (waiting on the new internal one arriving) and have had no end of problems:
Now, most of that screams "BIOS Update and new PSU!" so I've ordered a new 850w PSU and will get the BIOS updated as soon as it turns up. It's also coming with an SSD and the internal BD writer. However, I'm interested in any other thoughts you guys might have? Anyone got any experience of a similar setup? Is that board known to power off and back on again rather than just restart? Even when you save BIOS settings and restart it turns off for a second, then powers on again from cold.
Thanks everyone
- Intel Core i7-3930k CPU
- G.Skill 1600MHz 8x4GB CL9 32GB RAM
- Asus P9X79 Pro motherboard
- Intel RTS2011LC liquid cooler
- 2x (recycled) Gigabyte GTX260
- Seagate 1TB SATA 6Gbps HDD
- HiPro 700W PSU (recycled from an old Alienware machine)
- Couldn't get Windows to install. Whether I chose the UEFI or standard boot, it always complained about missing files
- Removed 16GB and a video card and it did install OK
- Put the second card in and the rest of the RAM and it appeared to be OK
- Full memory test appeared to have either locked up or only got to 21% over night (approx 7 hours testing)
- Powers on, powers off, then powers on again and boots
- Often no working keyboard or mouse in Windows, whether legacy USB is enabled or not, whether using USB2 or 3 ports, even though they're lit up as expected (but locked up also. Num lock is on, but can't be turned off)
- Sometimes powers on, then off, then on again a few times, as if it's cycling something and testing
- After it all appeared to have been working OK, I powered it on to get a warning message about the CPU only being running at 12x 100MHz and to check for errors
Thanks everyone
