The Storm Trooper has such a big presence and is now the lowest price in the UK.
The Antec P280 is all about near silent operation, whilst maintaining cool temperatures.
CM Storm Trooper Full Tower Gaming Case - Black @ £116.99 inc VAT
nonl2brCM Storm unleashes a truly magnificent feat of engineering into an arena that represents the future of warfare; the Trooper full-tower chassis. Capable of lightning fast redeployment, it’s the first in its class to include an ultra-strong carrying handle; allowing a gamer to travel with the finest system configurations available with relative ease. CM Storm Trooper includes features that are most coveted by gaming enthusiasts in that it has full dust filter coverage, a fan controller, an external SSD drive hot-swap dock and two uniquely designed modular hard drive cages. These features give CM Storm Trooper the ability to adapt to workstation or water-cooled gaming configurations easily.
CM Storm Trooper exterior features a damage-resistant rubberized coating that will protect the case during transport. Things heat up as gaming becomes more intense. The included front panel connections and controls provide a user with the ability to make on-the-fly changes to fan speed and case LEDs while USB 3.0 and 2.0 ports, and audio connections are also provided as an added means of convenience. This is topped off by a 2.5” HDD/SSD X-dock that makes mounting extra drives as easy as loading a Blu-ray/DVD. Changing settings at a moment’s notice becomes a simple matter of a quick button press with CM Storm Trooper.
CM Storm Trooper contains two modular HDD cages which can hold 4HDDs and a120mm fan for cooling each. These modular units can be rotated, front to back, side to side or removed altogether. CM Storm Trooper is the first chassis to allow fully modular hard drive configuration with no modification required. CM Storm Trooper can be equipped with multiple watercooling radiators.
Creatively mounting a vertical water-cooling radiator is possible with the removal of the hard drive cages and panels. CM Storm Trooper has nine expansion slots providing support for multi-GPUs in SLI or Crossfire, space for up to 14 hard drives, and a motherboard tray that supports up to XL-ATX. The Trooper is an ideal mobile arsenal to house and transport the most advanced system and cooling setups.
A professional cable management look is possible by utilizing the myriad cable tie zones and cable management holes available in the CM Storm Trooper. Smarter and larger placements of these areas allow for efficiently routing cables directly to their intended destinations. In an effort to reduce installation times, a great number of hardware can be mounted tool-free via the use of the included locking mechanisms or trays. A very large CPU heat sink retention hole has been placed in the motherboard tray to allow it to be compatible with most types of CPU and motherboard layouts. Prepare for the unexpected as seasoned operative would with a hidden drawer placed behind a false panel. The bottom panel removes to reveal a storage drawer to keep private effects safe from prying eyes until they are needed.
- Material: Steel body, Front Mesh / Plastic bezel
- Dimensions: 250 x 605.6 x 578.5 mm (9.8 x 23.8 x 22.8 in)
- M/B Type: Micro-ATX, ATX, XL-ATX
- 5.25" Drive Bays: 9
- 3.5” Drive Bays: 8 (converted from 5.25” bay by two 4-in 3 HDD modules)
- 2.5” Drive Bays: 13 (converted from 5.25” bay by two 4-in 3 HDD modules)
- Front Cooling: 120 mm LED fan x2 (1200 RPM, 17dBA)<br>
- Top Cooling: 200 mm fan x 1 (1000 RPM, 23 dBA)<br>
- Rear Cooling: 140 mm fan x1 (1200 RPM, 19 dBA) / (converted to 120 mm fan)<br>
- Bottom Cooling: 120 mm fan x 2 (optional)
- Side Cooling: 120 mm fan x 2 (optional)
- Expansion Slots: 10
- I/O Panel: USB 3.0 x 2 (internal), USB 2.0 x 2, e-SATA x 1, Audio In and Out ( Supports HD audio)
- Maximum Compatibility: CPU cooler height: 186 mm / 7.3 in / GPU card length: 322 mm / 12.7 in
Only £116.99 inc VAT.
ORDER NOW
Antec P280 Super Midi Tower Case - Gun Metal Black @ £109.98 inc VAT
The Antec P280 epitomizes cooling, quiet and sophistication. The durable polycarbonate layer prefitted deadens any noise and ensures Quiet Computing™. The P280 also boasts an new all black interior for a new updated feel from the older P180. . Additional features include two internal 2.5" SSD bays, and a mountain of 3.5" bays, excellent cable management and a special gunmetal gray finish for one-of-a-kind style.
- Supports up to XL-ATX Motherboards
- 9 Expansions Slots
- Quad GPU Support
- 6 Cable Routing Holes
- Bottom PSU mount with dedicated air filter
- Maximum Size CPU cutout
- Suipports GPUs up to 330mm long
- Top Power/Reset Buttons
- Front I/O Ports: 2 x Audio / 2 x USB3.0 / 2 x USB2.0
- 3 x 5.25" Drive Bays
- 2 x 2.5" Drive Bays
- 6 x 2.5" Drive Bays
- Top Cooling: 2 x 120mm TwoCool Fans
- Rear Cooling: 1 x 120mm TwoCool Fans
- Front Cooling: 4 x 120mm Fans (optional)
- Removable filters on PSU intake and front intakes
Only £109.98 inc VAT.
ORDER NOW
ORDER NOW
- Quad GPU Support
ORDER NOW
