Told you they'd be noisy didn't I.
What motherboard do you have?. I can see its a Gigabyte from the image at the top but it doesn't state anything more.
PWR probably refers to the Power fan header which is usually 12v with no PWM or DC regulation function. This is normally where you'd connect the fan from the power supply if it were externally powered.
The CPU fan is usually a 4 pin PWM connector (but also fits 3 pins) and if it's like my Gigabyte board remains the only one with a controllable PWM signal.
If your pump is connected there it is waste as you aren't supposed to slow that down. Might be more advantageous to have your radiator fan connected to the CPU header and control it via your bios or the Gigabyte fan software. Using a PWM splitter here allows you to hook up several PWM fans and have then controlled in a similar way that reacts well to temperature increases.
