My logitech Z2100 2.1 speakers have an issue with the controller where they have a lot of static build up when I turn them on and it takes a few minutes for this to disappear. Its been like this for around 2 years now, if not longer, yet now I'm starting to also hear static in games as well when things are quiet. I use onboard sound at the moment on my asrock mobo, which isn't bad, but does suffer massively from whitenoise on my headphones when plugged in via the front panel. I had to buy a cheap cable to lower the audio quality to get rid of this noise, which isn't exactly the worlds best fix is it lol.
Probably gonna need a soundcard, PCIe only (it'll sit above GPU1 whilst a pipe blocks my PCI port under GPU2), then also a new set of 2.1 speakers. I'm use to good bass quality and rather sharp audio, so I wish to continue this with the upgrade.
Now, is this possible for around £200 tops?
