- 16 Jan 2003
- Nottingham
Official specs
Performance seems to be between an HD6850 1GB and HD6870 1GB:
http://www.techpowerup.com/160476/Radeon-HD-7770-Put-Through-3DMark-11.html
So the same amount of texture units and ROPs as the 5770/6770, but less stream processors, less compute power and less memory bandwidth? Seems bizarre to me unless AMD are purely going for an 'Eco friendly' card? Can't see the faster core making up the perfomance lost via the aforementioned stats, unless of course I'm missing something![]()
I'm assuming the die hard fanboys of the 7000 series will be in here soon, saying the 7700 series isn't overpriced when it's equal/beaten by the 6800 series and also more expensive.
Different shaders.
The 6770 is a rebrand of the 5770 which uses different shaders.
Point in case the 6870 and 5850, the 6870 has a ton less shaders, but the 6870 is faster.
This card will be below the 6850, but make up ground in DX11.
I see, but do you think these different shaders are going to make up the other shortfalls I mentioned?
I thought the 6770 was essentially the same card as the 5770, didn't realise that it used different shaders?
Oh, I meant as in the 6770 used the old shaders (The ones the 5770 used) ergo, different to the 68XX series.
At 640 shaders at 1GHZ, it'll fall short of the 6850 in the majority of games, but have a foothold in DX11.
I don't think it's worth the asking price as a GTX560 or 6870 are much better buys.
Also, can't see the 7770 OC'ing *that* high percentage wise.
I thought there was a slip of the keyboard there
Yeah, I can't see it being much faster than the current 6770, even with it's more efficient shaders and higher core speed. About the only thing going for it, from what I can see, is it will be more economic to run.
It should be a fair bit faster than the 6770 and 5770 in DX11 app's.
You reckon? You could be right I guess, it'll be interesting to see the benchmarks that's for sure.
However,even the HD5770 1GB was not that great at launch either. The major improvements it brought were much lower power consumption and DX11.
When it launched the HD4870 1GB could be had for less and was generally faster :
http://www.anandtech.com/show/2856/5
The 4870 wasn't that much faster than the 5770 though, they traded blows in the majority of app's.
Also, don't cherry pick benchmarks. It's lame as hell.
Also, the 7770 is a double generation skip.
But yeah, the 5770 wasn't that good at launch, but it certainly wasn't as bad as the 7770 will be.
The 7770 is struggling to keep upto a 6850, while being a decent 30% more expensive (100 quid models of the 6850, even 90 quid models, and 130 quid models of the 7770)
