Still puzzled about my Laptop ?
27 Jan 2005
Letchworth Herts uk
Hi All i,m still puzzled about the playback on my Dell XPS L702 3d laptop i know the res is 1920x1080 16:9 but every blu ray and dvd i play i get these black bars at top and bottom .I have tried every player i can also changed the AR but still nothing :confused: am i missing something here or is this normal with these widescreen films ?:confused: The only film that plays full screen without black bars is The day after tomorrow on dvd useing the Classic Media Player
What does the packaging say the film aspect is? If it's wider than 16:9 there are going to be black bars.
(IMO this makes a nonsense of the claims that 16:9 monitors are better for watching films)
the box says 16:9 2.4.1 whatever that means ? :confused:
Yea, the majority of films aren't presented in 16:9 (1.77:1) aspect ratio - mostly it is 1.85:1 or 2.39:1. Therefore, when you watch one of these films on your display then you will see black bars at the top and bottom. You do have the option on most video players to crop the image so it fits the image to the whole screen - however it has to chop off the side of the image to maintain the proper aspect ratio of the image - so this isn't always the ideal solution.
16:9 displays (like your monitor) were introduced first in the TV market before they crossed over to computers - since they offered better presentation of widescreen movies (compared to the more square 4:3) and eventually allowed 16:9 TV shows to become the standard.
16:9 is basically a trade-off for PC monitors - it is perfect for TV shows and films shot in 16:9, looks nice is games (though many would argue that 16:10 is better) and is superior to 5:4 or 4:3 for widescreen movies - however it generally isn't as good for desktop work (where vertical height and resolution are often more important than width).
You actually can get TVs specifically made for widescreen movies, for example Philips make the "Cinema 21:9 TV" - which is a big telly with a 2.33:1 aspect ratio. So using this TV for 2.39:1 films there are basically no bars. However, for other content the aspect ratio isn't ideal -as you can imagine.
Thanks cmndr Andi that has cleared up my problem ha! i thought it was to do with my settings of the Laptop ,but when every film and software i tried was the same i knew it was a more deeper thing , if i,m honest i quite like the bars and don,t find it a problem as the picture quality is what its all about and on blu ray its awesome :)
