- 20 Jun 2010
Yep, tried a super soaker. Trouble is that he sneaks into the conservatory and even my best ninja style moves don't seem to be quick enough to get more than a couple of shots off at his back end dissapearing out the cat flap.
I have thought about using some other liquid in the super soaker........
I've also looked into changing the staywell cat flap for something better but I used staywell plastic tunnel to go through the wall in the conservatory brickwork so i'm limited on options (and on funds).
I bet you do it ninja style, all quiet like, and get miffed when it comes back.
To chase off a cat, you have to get over the top and melodramatic. Rather than squirting it with a water pistle (which it probably finds amusing), stare it in the face, make LOUD noises, clap your hands, stamp your feet and make to chase it.
You have to trigger its bolt-flight response which will make it think '**** I'm not going there again'. Just squirting it with a few ml of water it's more likely to think '**** you man, I'll be dumping in your flower beds later'
