Caporegime
- 28 Jun 2007
- Tamworth, UK
Re-build the pyramids.
With regards to the plane on a conveyor belt, I'd also like to point out a story from an old WW2 pilot i knew, sometime after the war he was flying a light aircraft into a small airfield. Now the landing speed of this aeroplane was about 70knots, and the wind speed was about 70mph. He had to perform a rather tricky manoever and actually landed the plane vertically like a harrier, once on the ground with engine still running and the airspeed indicator still reading 70mph he had to get some ground crew to come and hold the wings of the pane down and chock up the wheels so he could turn the engine off.
Basically if you put a plane on a treadmill that was at the same speed as take off then it would fall off the end very quickly, if you increased the speed of the treadmill with the speed of the engines then the plane would stay on the treadmill. If wouldn't take off though because the plane would only be going fast enough to stay stationary with the air and it is the movement of air over the wings that creates lift. Helicopter becomes a little more tricky because of the tail rotor.
Yes it does. Argghhh this is insane.
When an engine is off, you have to compress the air, suck in air and all that yourself. Hence the huge resistance. When engine is on, you have explosions that not only do all that work for you, but gives a massive amount of extra energy out.
So you couldn't be more wrong.
*facedesk*
conveyor belt movement != air movement
mythbusters have proved this one with a full size plane. it is a fact that a plane on a conveyor belt will take off no matter how fast the conveyor belt is going
If it was an infinite conveyor belt though and the plane had to start from zero it wouldn't take off because the wheels are still attached so it would never get forward momentum.
This would only be true if the spin speed of the wheels was limited to the speed of the experiment.
That doesn't even make sense. The resistance is always there due to gear and bearing friction. The reason I can't push a heli rotor around by hand isn't because "it has to compress the air" it's because it is attached to large hunks of metal which are attached to even larger hunks of metal being held in place by large chunks of metal.
Think about it, the plane is travelling at 700mph backwards, or whatever Vmax is in a 747, no way is it ever going to take off!
yes it would take off. the sum total of the effect of a conveyor belt on a plane is making its wheels spin backwards. while this will have a very tiny effect on the planes speed it will not stop it from taking off because a plane powers itself with a giant prop/jet engine blowing air backwards which, by newtons laws, makes it go forwards
mythbusters have proved this with a full sized plane and conveyer belt.
back to the helicopter on the turntable:
helicopter spins anticlockwise at 100RPM
engine has max speed of 100RPM in other direction
engine cannot rotate relative to the helicopter, so the engine itself is rotating at 100RPM anticlockwise, or -100RPM clockwise
engine gets to max speed of 100RPM
blades go at -100RPM + 100RPM = 0RPM
how you think that an engine that is rotating has no effect in the internals boggles my mind.
No the Ground is moving the wheels 700 mph.
The forward thrust (Air thrust) is also still moving the vehicle forward at 700 MPH
So your wheels spin at 1400 MPH but you still have your relative movment forward using air thrust.
