It is a shame that Glaucus is wrong because he was more correct in understanding the physics than more or less everyone else.
Most of the people saying Glaucus was wrong believe that a plane could not take off from a conveyor belt, and thus are truly ignorant of the physics.
if you had a a pair of rotor attached with frictionless bearings to a shaft connected to a rotating turntable, then the rotors wont rotate, merely the the shaft with the bearings. This case is like the plane on a conveyor, the rotors being unattached to the shaft.
[FnG]magnolia;21281947 said:Two sandwiches. Two. They're distinct and discrete from one another.
All this arguing over helicopters. I take it nobody saw the plane on a conveyor belt episode then? Same principle and it still takes off.
not completely independant of each other with no 'force link' as Glacus was suggesting - if that was the case no engine/motor could produce any torque.
[FnG]magnolia;21281654 said:This is a fact rather than a myth but if I have one sandwich and then I cut it in half, I now have two sandwiches. Where did the other one come from?
Anyway - sandwiches. Well clearly if you cut a sandwich in half, the two halves both still meet the definition of a sandwich (two bits of bread with filling between) so you can call each half a sandwich in its own right. So you have two sandwiches. Exactly as, for example, a piece of wood. If you cut a piece of wood in half you now have two pieces of wood. Sandwiches, wood, many more - yes. Cars, humans, etc - no. The two halves would not still meet the definition of the object. Not a difficult one, that one.
I think you'll find that if you cut a piece of wood in half then you have a saw.![]()
Er no - not the same. But been done to death now - see above.
