Newly built system wont start
9 Nov 2010
Hey guys, ive recently built a new system, however, i cannot get it to start, my old SSD has a copy of windows on it, but will not let it boot, instead its telling me to put in my windows cd and repair compute, which i am doing, but the repair keeps freezing on the windows screen, both launch and repair freeze on the windows screen, i am yet to get to the desktop.
Does anybody have any tips on how to get this system up and running?
Best regards,
Sam
You need to reinstall Windows if its a new PC
+1
New system or even a new motherboard means you need to install a new fresh copy of windows.
I know it's a pain in the ass but unfortunately we have no choice.
Here is what you need: Windows 7 Home Premium 64bit
If you do not know the difference between 32 and 64 bit then 32 bit only allows a maximum of 3GB memory and to a gamer like myself that is useless. Near enough every gaming system now use a minimum of 4gb memory, so 64bit is needed. 64bit allows an unlimited amount of memory to be in use, depending on your motherboard of course.
My motherboard allows up to 32gb memory to be installed, though I only use 4gb. Some motherboards like the new X79 chipset from Intel for the new Sandy Bridge Extreme LGA2011 CPU's can support up to over 100gb of memory. It all depends on your board and what type of CPU you are running.
64bit F T W
I don't know if you have a 'traditional' hard drive installed as your new SSD, but if so, make sure that you disconnect it, before reinstalling Windows on the SSD.
You can sometimes get away without reinstalling but moving from an AMD to Intel, or vice versa, pretty much always requires an install. Still is best practice though.
Because that's what everyone says you should do! ;)
Seriously though, one of the reasons is that Windows still likes to configure any 'traditional' hard drive as 'Drive 0' and to install Windows onto that.
Yes, you can always tell it that you want it all on the SSD, but it is still going to want to stick 'bits' on the other drive... something like that anyway! :)
You can re-connect it immediately after installation, of course!
I am sure someone else will come up with a better explanation than this though!
As long as the HDD is totally blank then you shouldn't have an issue. Its when there's been a previous installation of windows and the installer decides to use the boot sector still on the old hard drive that you can run into issues. Otherwise you should be fine.
im interested as i reinstalled windows earlier today with 3 media drives in it at the same time
this sounds more likely to me - thanks :)
