Graphics card / CPU question
Yes, they will work fine, but what PSU & motherboard are you using, also double check your case can take the size of card.
Will this graphics card "GTX 570 HD w/Display-Port" work without issue with
this CPU " is amd athlon II x2 255 Processor 3.10ghz"
Thanks for your time.
Sure that card 'should' work fine but at the same time that 570 is way OP foy your cpu!
Theres a certain overused term that springs to mind, starts with 'b' :)
could be a slight bottleneck from the processor mind. a dual core "might" not be powerful enough to keep up with the 570... overclocking it might help... also depends on what resolution do you play at?
