Old timer, spec check
29 Apr 2007
Been a while since I've built a home PC (I look after enterprise servers for a living).
The following is for an HTPC build. Want a cheap solution but something with reasonable power to watch the occasional HD film (Mostly iplayer etc)
AMD Athlon II X2 260 3.2 GHz Socket AM3 2MB Cache Retail Boxed Prcessor
Corsair 4GB (2x2GB) DDR3 1333MHz Memory Kit Unbuffered CL9
Asus M5A78L-M/USB3 AMD Socket AM3+ 8 Channel HD Audio mATX Motherboard
LG GH22NS70 22x DVD±RW with DL & RAM SATA Optical Drive - OEM Black
Black/Silver Super Slim MicroATX Mini Tower Case - With 200W PSU
Look ok?
YOUR BASKET
1 x Asus P8H61-I Intel H61 (Socket 1155) DDR3 Motherboard £68.99
1 x Intel Pentium G620 2.60GHz (Sandybridge) Socket LGA1155 Processor - Retail £47.99
1 x Cooler Master GX 450W '80 Plus' Power Supply £35.99
1 x Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £23.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £205.44 (includes shipping : £11.25).
Well that's a mini-itx mobo about as small as you are going to get. The RAM is 1600mhz CAS 9, i thinks it's worth the lil extra over 1333mhz myself (to reuse it later maybe).
I included a good budget PSU too. I don't know what you are paying for those parts in your spec but i imagine that 200W PSU will be rubbish and a liability to the build. If you want to strike off the 450W PSU and go with a case you like with a supplied PSU that is your call.
Case is largely personal preference anyway so I'll leave you to find something you like fella. Hope this helps
YOUR BASKET
So is my original spec no good?
It's mainly that you don't want to be on that AM3 socket fella. I like the llano stuff for HTPC as it's IGP is very very good but again it's a "limited" socket type.
You went with the athlon X2, the pentium G is a amd phenom rival with it's L3 cache. That H61 mini-itx mobo has USB3. You do however get the choice of the Pentium G/i3/i5/i7 CPUs...... plenty of upgrade paths there then ;)
http://www.anandtech.com/bench/Product/190?vs=406
If you want to use a full atx case (which the OP did say he didnt want) then you don't need the mini-itx mobo.
YOUR BASKET
1 x MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** £61.99
1 x OcUK Opera Media Case - Black (with 500W PSU) £39.98
Total : £200.94 (includes shipping : £10.00).
Better RAM CAS9 instead of CAS10. Better CPU, mobo still has usb3. I still would put the PSU in the bin myself.
Oh right. Is AMD that bad now?
Would a micro-atc format be better? that was the size I was aiming for.
I would choose the llano over the g pentiums anyday and why would you need to upgrade if you went for llano it will handle video no problem unlike g series onboard which has problems.
Gigabyte GA-A55M-S2HP
AMD Llano A6-3500 2.40GHz
CML4GX3M2A1600C9B - 4GB (2x2GB) Corsair DDR3 Vengeance LP Cerulean Blue, PC3-12800(1600)
Samsung WriteMaster SH-S222BB/BEBE
£200 from ocuk and other place
YOUR BASKET
1 x AMD Llano A4-3400 2.70GHz (Socket FM1) APU Processor (AD3400OJGXBOX) £53.99
1 x Asus F1A55-M LX AMD A55 (Socket FM1) DDR3 Motherboard £44.99
1 x Corsair Builder Series CX 430W V2 '80 Plus' Power Supply (CMPSU-430CXUKV2) £39.98
1 x Fractal Design Core 1000 Midi Tower Case - Black £32.99
1 x Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT25664BA160A) £19.99
Total : £221.93 (includes shipping : £12.50).
Llano has good integrated graphics that will even handle light gaming. A nice case, and good PSU too, don't ever skimp on a PSU - those which come with cases are usually terrible.
But the OP asked for small form factor which is why i originally used the mini-itx mobo and let him find a suitable case for it. Is there a mini-itx FM1 socket mobo?
I already said I like Llano for HTPC builds because of the good IGP. I'm just pointing out all the avenues to the OP so he can make an informed decision fella.
They do have on board GPU.
But for blu ray you need a PCI E GPU.
You can watch blu-ray with it you but they are not recommended and no 3d support.
http://www.anandtech.com/show/4524/...-review-pentium-g850-g840-g620-g620t-tested/6
His original build was matx that is why I matched that.
fm1 does have a few mitx they start from £70+ but not from ocuk.
You can watch blu-ray with it you but they are not recommended.
Well that confused me too when he dismissed freddies llano build when it was the same form factor as his spec :/ That's why i did the mini-itx pentium G build.
http://www.anandtech.com/bench/Product/403?vs=406
As we have pointed out the IGP is much better on the llano APU. That said i still favour the sandybridge mobo for being able to take a greater range of CPUs. You can always add a cheap dedicated GPU later.
Hello,
I have a geforce 6400? (off teh top of my head in my existing pc) its a low profile HD card (I use HD to connect to my TV).
So bearing in mind the graphics card isn't a worry. Intel or AMD?
