Basically i have this setup at the moment and if i "could" Go single loop it would look a lot better!
I am planning on getting SLI 680's so they will be added into the loop, so it will basically be going Res > pump > RX120 > Mobo Block > Gfx 1 > Gfx 2 > RX360 > CPU > RX120 > Res
Now people have said having 1 loop and having 1 D5 cool all that is pushing it and i will run into temp problems.
All the rads are push/pull RX 360 has 3 GT 1850's on pull and 3 12.5mm fans on push, the bottom RX120 has 2 GT 1850's and the front RX120 has 2 Vipers now. All on full RPM.
But i have my 2700k @ 5ghz 1.38v. But i will probably lower this to around 4.8 when i go SLI
So what do you think? Is 1 D5 pump cooling that lot asking a lot from it? I have seen a youtube vid of someone doing it. But i would hate to sale my 2 DDC's to gimp myself on temps!
 i will post back!
