In short no.Is there a direct correlation between watts and heat output?
Wow Thanks guys more boffins than one could shake a stick at.
Just a word mate no disrespect, I'dont read the sun, its what my boss calls someone who knows more about a subject than he doesYou know what? I hate that word. The Sun uses all the time and it give off a whiff of reverse snobbery.
yes 23 years in the business and 40 years young in may (WooHoo life begins at 40) and i still have home workThe way you've written your last post sounds very much like homework!
cant do either, the unit is part of a production line.Move the lamps closer to the conveyor? Slow the conveyor belt down so the cans have a longer period of time to heat up and reach 250 degrees C
3) You need to alter the angle of the can with respect to the bulbs in order to get the optimum cross sectional area. I image with the way in which the machine is set up, this will yield little benefit.
4) Make the can/laquer thinner (probably impossible)
Lamps are as close as i can get them to the can, although the reflectors are a bit crap, i was advise to fit gold color reflectors.Any way you can move the lamps closer or use reflectors to focus the energy on the cans better?
Yes as advised by the lacquer manufacturerDo you have the optimal wavelength of infrared lamp for your coating? If your coating is water based, for example, using near infrared lamps will be ineffective - you need to use medium wave infrared for that.
Is there a way to calculate how much heat can be given off by say a 2000 watt infrared lamp? Is there a direct correlation between watts and heat output?
I will try and explain my problem, I work as an engineer in a can factory, we apply a lacquer to the inside of a tin can over the welded side seam to protect it from various aggressive products put in the can. The lacquer has to be cured at a temperature of 250c we currently do this by passing the can through a conveyor under infrared lamps taking 12 seconds to complete a pass through, this however does not cure properly, I cannot extend the conveyor, I cannot slow down the conveyor and I cannot use more lamps only increase the wattage. I can measure the temperature with a thermometer and know it can reach far in excess of 250c, I can also measure the temperature of the can, the can only reaches a temperature of 200c/230c. This was done with 5 x 1000 watt infrared lamps, I now have 5 x 2000 watt lamps yet the can only reaches 200c/230c. does this suggest the lamps become less efficient at a higher wattage? Surely not to this extent?
