Looking to build a new PC, looking for some advice...
23 Jan 2012
Need Mobo, CPU, RAM, PSU, Monitor and a GFX Card but that will come at a later date. Don't really have a budget but would like it as cheap as possible without sacrificing any performance :)
That board comes with a 3.0 slot. All it needs is a BIOS update I believe.
Edit: Ah it seems only the version 2.0 of that board has PCI-E 3.0, if you particularly want that board, you could ask OC which version of the board they have in stock. Otherwise, this board is also pretty decent. http://www.overclockers.co.uk/showproduct.php?prodid=MB-054-AK
TBH, with the latest generation of cards, PCI 3.0 makes little difference, but who knows with future cards.
Going to go with...
Mobo: http://www.overclockers.co.uk/showproduct.php?prodid=MB-198-MS
CPU: http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
RAM : ???
Looking for 8GB but have no idea which to go for... Looking to pay between £30 and £50ish, also not sure if I need Low Profile ram.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-114-KS&groupid=701&catid=8&subcat=1517
Low profile and cheap:cool:
P.S, that MSI board s out of stock,
Try this for a single GFX card - http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-GI&groupid=701&catid=5&subcat=1990
Or this if you want Crossfire/SLI@8X/8X - http://www.overclockers.co.uk/showproduct.php?prodid=MB-368-GI&groupid=701&catid=5&subcat=1990
