Hey
I work in a factory, my job is set up the machines for the morning workers to use.
There is a team of cleaners, who have to bag off all electrics on the machines, and hose down all the machines as I work in the food industry everything has to be clean.
3 machines are on wheels, I have to bring them out from a room and put them by the conveyor belts to use. I then plug them in. Yesterday, I plugged the machine in, and the bracket for the sensor was on the wrong side.I removed the bracket no problem, as I held the bracket to put it back on, I received a bloody hurtful shock, and the RCD (30ma) tripped out.
The ambulance, fire brigade (!) and emergency response team arrived to treat me. I went to hospital and got discharged a few hours later.
When I arrived back at work, the other 2 machines had been found out to be faulty. Water had got into the electrics on all 3 machines. The guy who had cleaned all 3 had not bagged them off, and water was happily sitting in the 240v plugs.
Due to his neglect, I could have died. It is not my job to remove plugs and check for water, the supervisor of the cleaning team is tere to check yet have done their job properly.
Thanks for the speed replies! This place is busy
