Which graphics card for £50 - £100?
With the 5850 couldn't I just ramp up some AA if it's bottlenecked? Also the 5850 seems to be better on power.
Depends on what you are paying for it mate.
If it's not really cheap you're pouring perfume on a pig.
I'd say less than £70 and you're good.
Too much. I've seen 5870s change hands for £90.
I would top out at £70 for a 5850. Reason being you can get a brand new warranted 5830 for about that and it won't make much difference in your PC.
The 5770 would already be good enough for that, when the CPU is already holding back a chuck of GPU usage. Also, using 8xAA instead of 4xAA doesn't really make a game more enjoyable with the frame rate still drop to low 20s and average at around 40fps...it's just a bad justification for increasing GPU usage, rather than increasing frame rate/performance.
Ok cheers.
Actually rather than getting a graphic card upgrade for a clearly aged system...may be see if you can find the budget to upgrade the platform as well?
For example if you are on a budget, let say if you go for something like a G840 CPU for £55, a socket 1155 H61 board for £45, 4GB DDR3 memory for £20, that's just £120 total. Add something like a 6850 to it for £100, and you will have a decent gaming system on a small budget of £220. If you can add another £30 to your budget, you can get a Gigabyte Z68AP-D3 Z68 board for around £75, which will future-proof you if you were to upgrade the CPU to a K-version of the SandyBridge/IvyBridge in the future and would allow you to overclock them.
Actually rather than getting a graphic card upgrade for a clearly aged system...may be see if you can find the budget to upgrade the platform instead as well?
I actually had no intention to upgrade at all, the problem is caused by my 7900GTX not having sound on HDMI, which prompted me to look at graphics cards which has now been suggested that I do a full upgrade :p
In that case, just grab a 2nd hand 5770 1GB (think it's around £35). It would be more than enough for your need and more than a match for your system.
On the auction site it probably would be. Looking at your join date and post counts for this forum, you should have access to the members market...try have a look there instead. I've seen 5770 1GB going for under £40.
That's where I was basing that figure on.
Just seen how insanely cheap DDR3 is, I might be swayed yet.
I recently bought a Sandybridge Celeron that is every bit as good as an E8400 in benchmarks. It was £30. More info here.
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Celeron+G530+@+2.40GHz
I bought an Asrock H61M-VS for £39.99 and 4gb Corsair Vengeance blue for £23. IIRC it was like £94 all in delivered.
And it rocks. The CPU can't be overclocked so you just stick on the stock cooler, but my media PC is pretty rapid I have to say. And at that price it's not worth even bothering faffing around trying to find second hand gear because the CPU wipes the floor with any competition in that price bracket even second hand.
Infact no, that's not fair to the Celeron. It piddles on CPUs I've seen change hands second hand for £45.
Actually this is the better link.
http://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Celeron+G530+@+2.40GHz
